Lsj Throttle Body Troubleshooting
#61
Posted 09 March 2015 - 04:01 AM
#62
Posted 09 March 2015 - 10:58 AM
#63
Posted 17 March 2015 - 06:20 PM
New sensors installed. The main sensor has been replaced with a genuine part and the second sensor has been replaced with an aftermarket one.
Misfires still present.
If I blip the throttle from idle, the engine stalls.
In neutral, gently bringing the revs up I can feel the misfires constantly between 1500 and 2500rpm consistently.
#64
Posted 17 March 2015 - 07:14 PM
#65
Posted 17 March 2015 - 07:48 PM
#66
Posted 18 March 2015 - 01:20 PM
mine looked ok wasn't until the pipe was off that I realised it was sliding up and down as the welding had gone.I had a snake camera in there while the sensors were out and it looked intact.
#67
Posted 18 March 2015 - 02:09 PM
Could you hear any noise from it moving? Mine's got a tinny rattle from the resonance at very low revs, but I think that's just the heat shield which doesn't fit perfectly with the aftermarket exhaust.
#68
Posted 18 March 2015 - 02:38 PM
Probably not the same issue, but mine stuttered and sometimes stalled on blipped throttle and it was the MAP sensor. I see you've had a new TMAP so its probably not that but thought it worth a mention.
#69
Posted 18 March 2015 - 03:02 PM
#70
Posted 18 March 2015 - 05:35 PM
cheap pattern map sensors cause serious problems, you should only use genuine map sensors
#71
Posted 18 March 2015 - 07:07 PM
TMAP is genuine Bosch
I only used a cheap sensor for the post-cat lambda.
#72
Posted 19 March 2015 - 05:20 AM
#73
Posted 24 March 2015 - 10:23 AM
Peter has tweaked the base map slightly and now the misfire persistence has reduced. The engine no-longer cuts out when the throttle is quickly applied.
Still getting the misfires on gentle throttle though.
Does anyone with some experience working with OBD tuner fancy a day helping me sort the map out? I'm happy to reimburse you for your time and travel costs.
#74
Posted 25 March 2015 - 06:20 PM
#75
Posted 26 March 2015 - 07:52 AM
Just gone through your thread and - have you tried a new/different coil pack? - is it clean between plugs and coil pack? - what are your plugs gapped to? Try them at .7mm - failing the above check the cam timing? I had lots of stuttering/misfire on Dutch that didn't exist on CS map solved by dropping the plug gap from OEM 1mm to .7mm
Thanks for the advice.
I haven't tried a different coil pack, but the contacts on the pack and the plugs are both clean.
Plugs were gapped to 1mm but I set them to .7mm a week ago, there was no difference to the way the engine ran.
I haven't checked the cam timing - it looks like I may have to even though I installed everything to the correct timing marks it is possible the cams were manufactured slightly out. Although, the old engine also misfired and that was running standard internals with a timing chain installed by Vocky not many miles before it came into my possession.
I'll see if I can borrow a coil pack from someone to rule that out.
#76
Posted 26 March 2015 - 08:26 AM
I remember your car now, both chains done with genuine parts and the balancer delete on the replacement engine.
Try a coilpack
Edited by vocky, 26 March 2015 - 08:26 AM.
#77
Posted 26 March 2015 - 01:31 PM
#78
Posted 26 March 2015 - 03:10 PM
What cams are in?
Some of the ZZP Comp's had base circle issues that causes misfires and idle issues. But your's is idling OK @ ~800rpm, right?
Maybe post an idle log so we can see where it misfires?
#79
Posted 26 March 2015 - 03:37 PM
What cams are in?
They're Comp Cams Blower cams.
It idles OK.
I'll dig out a log when I get home. I'm not sure how you spot the misfires in the log since the 'misfires' data in the logs never records any even when they can be felt whilst driving.
#80
Posted 26 March 2015 - 03:56 PM
https://drive.google...iew?usp=sharing
This is a log of the engine idling and then me blipping the throttle to try to replicate the cutting out.
I've not got OBD Tuner on this PC so I can't see if I did any low rev stuff on there, but if there is any at all held around 2000rpm for any amount of time then it will have been misfiring.
