Alternative Oil Filter Seals
83 replies to this topic
#21 tomooooose
tomooooose
  • 12 posts
Posted 03 February 2015 - 06:43 PM
1. RabnaKS 2. vocky - 2 pairs 3. Phear - 2 pairs 4. VX220BOB - 2 pairs 5. Navx - 2 pairs 6. Myles - 2 pairs 7. Sticky - 2 pairs 8. Chippyfa - 2 Pairs 9. Zimmer - 2 pairs 10.Ni S - 2 pairs 11. Graeme Lambert - 4 pairs? 12. Stevie Dubyah - 2 Pairs 13. Nickb777 - 2 Pairs
14. Bootdog - 2 pairs,
15. Yaaan - 2 pairs
16. tomooooose - 2 pairs
#22 AllanM
AllanM
  • 53 posts
Posted 04 February 2015 - 10:40 AM
Are we talking about nr 5 ?
I have never near this when changing oil.
#23 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 04 February 2015 - 12:31 PM
The parts (12 & 13) seize together if the top is done up too tight. Then you need new seals when undoing the two parts. Sounds like yours are fine, congrats.
#24 TheHood
TheHood
  • 1,036 posts
Posted 04 February 2015 - 08:24 PM
15. Yaaan - 2 pairs
17. TheHood - 2 pairs
#25 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 04 February 2015 - 09:53 PM
Yep, we are talking about item 5.... Still waiting on a bit more info. .. Update coming soon....
#26 RabnaKS
RabnaKS
    If anyone can talk Bllx, I can!💣
  • 2,717 posts
  • Interests:MTB, VX220, oh & cars, golf, sarcasm with humour!
Posted 04 February 2015 - 10:03 PM
How are we talking about No. 5? I'm under the assumption it is No. 14, the gasket seal between the oil filter cup & the top that you remove to put the oil filter in?😳
#27 badgerade
badgerade
  • 1,173 posts
Posted 04 February 2015 - 10:14 PM
The supply of 14 isn't an issue - that is just a rubber seal.
5 is the part that isn't available, and which is needed if you can't split the filter assembly properly.
#28 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 18 February 2015 - 09:42 PM
Ok, here's an update. Having looked at the material I was thinking of it may have too a high a sealing stress and we may not be able to tighten it down enough. I have since sourced a graphite based material which is much better suited and can be manufactured to size. Being graphite it has a higher compressibility, so will be much easier to seal and is good for 400 deg c. I will be looking to get a trial set made up this week.
#29 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 18 February 2015 - 09:47 PM
Ps.. I've just done an oil filter change and am on the lucky position that the filtet housing came apart as it should. I have been unable to then break the lower part separately so am unable to test these seals. So I am looking for a Guinea pig.... is there anyone who currently needs a new set of seals who would be willing to trial these? I would supply them foc, along as they were fitted asap and feedback given. This will then allow me to source a collection so the orh can benefit.
#30 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 18 February 2015 - 09:48 PM
Pps... Whilst the graphite material is much better, it is more costly - but would still be looking at £15 a pair.
#31 yaaan
yaaan
  • 956 posts
Posted 19 February 2015 - 02:24 AM
I've just changed mine, but the car still isn't back on the road yet, so would be happy to pop on a pair of these to test if you want. I've got to get the car back together and through the MOT before I could do any real testing though, so I may not be the best guinea pig.
#32 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 19 February 2015 - 07:56 PM
If you fit them can you run the engine to check they seal ok?
#33 yaaan
yaaan
  • 956 posts
Posted 20 February 2015 - 09:12 PM
Yep, the engine's running. It just needs the clam back on and MOTing so I can run it to check the seals no worries.
#34 navx
navx
  • 369 posts
Posted 20 March 2015 - 08:00 PM
Any news on these or have they died a natural death?
#35 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 03 April 2015 - 08:46 AM
http://www.ebay.co.u...=item339d22a2c7 ? Seem a bit overpriced though
#36 slindborg
Posted 03 April 2015 - 08:51 AM
The op suggested £15 and got a standard epic list..... So a few quid more shouldn't break the pikey bank. Assuming they work
#37 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 03 April 2015 - 09:13 AM
Yeah it's the if they work bit that worries me. Esp as OP was fretting over the material to use and these are simple Ali. Plus I won't know until they're in so if the originals get damaged and they don't seal I'm fecked
#38 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 03 April 2015 - 09:24 AM
Sick of this shortage of rings and risk these others not working. I remember reading that there's a option to delete the whole ring setup so you don't have to use it anymore, just need to find the piece I need to buy.
#39 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 03 April 2015 - 10:51 AM
http://www.ebay.co.u...=item337e1f63a5
#40 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 03 April 2015 - 11:50 AM
Perfect. Where do the 2 oil pipes on top go or is this just blanked off for us?
