Alternative Oil Filter Seals
83 replies to this topic
#61 ghand
ghand
    Drunken lampposts only
  • 9,215 posts
    Oh and more whisky
Posted 14 April 2015 - 12:21 PM
I don't understand why folk don't just Locktight the threads and tighten well down, then forget about the bloody things for ever. That's all I did. Oh and don't over tighten the top it has an O ring so doesn't need swinging on. Like some bastard had done with mine :lol: .
Edited by ghand, 14 April 2015 - 12:22 PM.
#62 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 16 April 2015 - 05:06 PM
Ok, looks like the original trial set was made undersized somehow. New set has now been made and should be tested on the weekend.
#63 chappers2000
chappers2000
  • 489 posts
  • Interests:Sports cars; kit cars, mountain biking
Posted 16 April 2015 - 06:58 PM
  I know the relief valve is easily removed but it surely serves a purpose otherwise Vauxhall wouldn't have fitted on this particular install otherwise. Bypassing it by removing it doesn't seem like the best idea, if you're retaining the standard oil cooler setup. It doesn't exist on the LSJ/B207/Z20NET engines with the better integrated cooler which this remote filter adaptor is designed for.
  It only serves a purpose in the VX220 engine installation with their oil cooler setup.    The Vauxhall/Opel cooler is re-routed via a remote filter to the US adaptor connections.   Infact it has to be removed and the bottom hose connection plugged when using the US adaptor.   With your understanding of how things work, I would also have on sold this adaptor.   Perhaps some more research would be in order on your part.
Similar for me. I have a U.S. Adapter and was going to buy a remote filter and some hoses but I couldn't work out what needed to be done and what to do with the relief valve, if anything, and what to do with the oil pressure sensor. Did an intermediate oil change and just bought a 32mm socket but the 3/8 drive adapter has just sheared off as the filter is on so tight. Was going to try and split the filter from it's cap but haven't even managed to get it off yet, so fell at the first hurdle.😔 At least my engine mount inserts went in without issue.😊
Edited by chappers2000, 16 April 2015 - 06:59 PM.
#64 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 16 April 2015 - 07:41 PM
There was a group buy on here for the oil filter spanners not long ago - might still be able to get one. That will make it easier to get the filter out.
#65 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 16 April 2015 - 07:52 PM
Or you could ask to borrow one ;)
#66 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 16 April 2015 - 08:20 PM
Much better idea!
#67 007
007
  • 23 posts
Posted 16 April 2015 - 08:34 PM
I'm in too for a couple of pairs if I'm not too late.
007
#68 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 16 April 2015 - 09:37 PM
Pairs of gaskets or spanners....
#69 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 20 April 2015 - 04:49 PM
Ok, the new test gaskets were fitted on the weekend and fitted well with no initial leaks, so these look like a solution. Will know for sure next week once the car has been run a bit longer... Watch this space...
#70 phippsy
phippsy
  • 472 posts
Posted 20 April 2015 - 04:59 PM
I will be in for a couple of pairs if possible. Have an oil leak from the oil filter sandwich plate. Cant believe Vauxhall have discontinued these and left us all out in the cold :-(
#71 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 20 April 2015 - 05:09 PM
Looks like your timing is good!!!!
#72 phippsy
phippsy
  • 472 posts
Posted 20 April 2015 - 05:28 PM
Would be perfect timing if they have survived the test and are ready for manufacture :)
Sorry for some reason I cant copy and paste the list. Wanted to add my name to it for x2 pairs!
Cheers
Andrew
#73 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 20 April 2015 - 05:44 PM
No problem. Initial test looks good, but next week we should be able to confirm. Once available I'll start a new thread in the parts for sale section, and send a reminder via pm to all who have shown an interest
#74 phippsy
phippsy
  • 472 posts
Posted 20 April 2015 - 05:53 PM
Sounds good. I'll keep my fingers crossed and watch for updates then as im in a bit of a fix at the minute.
#75 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 20 April 2015 - 05:57 PM
How bad is the leak? Is it drivable?
#76 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 20 April 2015 - 06:07 PM
Also looking forward to these as an Oil change is nearly due on mine I would prefer to have these handy just in case
#77 phippsy
phippsy
  • 472 posts
Posted 20 April 2015 - 07:01 PM
Losing a fair bit of oil. Can drive it but I think I've probably lost half a litre over the last five days.
#78 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 26 April 2015 - 05:48 PM
Ok, looks like these new seals work!!!! Will sort out how many are left in the first batch and post them on the parts for sale section....
#79 myles
myles
    Sausagefest
  • 2,093 posts
Posted 26 April 2015 - 05:57 PM
Not going to use 'the list'?
#80 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 26 April 2015 - 05:59 PM
Will pm all on the list, but thought the fairest way was in parts for sale as this was only a im interested list.... There will be enough to go around though
