Ly No65 Weekend/nice Day Car
94 replies to this topic
#41 Haston
Haston
  • 198 posts
Posted 11 June 2018 - 12:47 PM
Had a look around them when the clam first came off and they look alright but I will have a closer look.
Will see if I can make it for a look.
I just seem to be adding more to the "to do" list every day.
#42 Haston
Haston
  • 198 posts
Posted 11 June 2018 - 03:24 PM
Another update.
Inlet manifold off and started stripping the cam chain off looks like it may have been out a couple of teeth 🤔.
Any recommendations on how to lock the crank pulley? Posted ImagePosted Image
Sent from my SM-G935F using Tapatalk
#43 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 11 June 2018 - 05:59 PM
In gear, handbrake on, or someone else presses the brake.
You can poke a drill bit through the hole on the pulley any turn until it jams against the webs on the cover.
Ideally you do it before undoing the tensioner or cams though!!
Edited by Tony H, 11 June 2018 - 06:01 PM.
#44 vocky
Posted 11 June 2018 - 06:56 PM
the chain can slip and bend a valve if you try and undo the crank pulley bolt by locking the cam sprockets with a bar, some are extremely tight !
I use a home made crank sprocket locking tool or if the starter motor is out I use the z22se flywheel locking tool
#45 Haston
Haston
  • 198 posts
Posted 11 June 2018 - 07:02 PM
Going to try timing it up and sticking it back together and using the starter motor method.
Big bar now ordered...
#46 Haston
Haston
  • 198 posts
Posted 11 June 2018 - 07:50 PM
Just been out.... Improvised and locked it, the pulley is now off along with the chain cover.
The question now is do I send back the 2ft breaker bar I just ordered 🤔
#47 Exmantaa
Posted 12 June 2018 - 08:34 AM
Why do you think the cam timing is out??
The coloured links will only line up once in so many revolutions...
#48 Haston
Haston
  • 198 posts
Posted 12 June 2018 - 11:48 AM
When comparing to the TIS guide the inlet looked slightly retarded, the angle the picture was taken at doesn't help.
#49 vocky
Posted 12 June 2018 - 03:44 PM
cam timing looks okay to me thumbsup
#50 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 13 June 2018 - 10:19 AM
Worth checking the brake servo vacuum hose whilst its all apart - runs through the sill also
#51 sford
sford
  • 1,459 posts
Posted 13 June 2018 - 02:25 PM
That was a right pain in the arse. Not really difficult just really annoying.
#52 Haston
Haston
  • 198 posts
Posted 13 June 2018 - 03:32 PM
Well the chains are off and the new waterpump is in place.
Does the servo line run down the passenger side?
Also any point in removing the balancer shafts while I'm in here? Posted Image
#53 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 13 June 2018 - 08:44 PM
You need the engine out to remove the balancer shafts.
#54 smiley
Posted 13 June 2018 - 08:55 PM
It is the one mod i regret doing on my car.
#55 Haston
Haston
  • 198 posts
Posted 13 June 2018 - 09:01 PM
Do you though? think I could work a way around it. It would be the pushing the bearing in that would be the difficult part.
Is it giving you that much more of a vibration?
Edited by Haston, 13 June 2018 - 09:01 PM.
#56 smiley
Posted 13 June 2018 - 09:15 PM
Yes, for me it is a bit too much.
#57 Haston
Haston
  • 198 posts
Posted 13 June 2018 - 09:18 PM
Will have a think about it tonight. If not onward with the fitting of new parts and getting the SC parts on 🙂
#58 smiley
Posted 13 June 2018 - 09:43 PM
If there is someone around with them removed and you could just sit in it with the enigne running, you could easily decide if it is for you or not.
#59 Exmantaa
Posted 13 June 2018 - 10:06 PM
And besides the vibrations; I did not see a real world power win with them removed...  :sleep:
#60 navx
navx
  • 369 posts
Posted 14 June 2018 - 05:47 AM
A claimed 10bhp here but original GM document link no longer available:
https://z22se.co.uk/...te-10-bhp.6809/
