Turbo Vs Supercharged
118 replies to this topic
#61 dw1
dw1
  • 3,043 posts
Posted 11 July 2015 - 12:45 PM
I wonder if the Dave Hardwick air box which uses a standard air filter would work or is that only for turbos?
#62 PaulCP
PaulCP
  • 6,066 posts
Posted 11 July 2015 - 12:49 PM
Or, if you were interested, I could help you out with one of these http://www.vx220.org...-ala-jg-for-sc/ Never fitted and probably never will be😉
#63 Eliselee281275
Eliselee281275
  • 155 posts
Posted 11 July 2015 - 09:40 PM
I have a couple of tubbies in if I can get that 111R back Lee!
Ha ha Jon get me that rotrex or simlair and we can do a deal on the best condition 111R around 👍
#64 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 11 July 2015 - 09:44 PM
Chances of getting that one are slim I reckon!
#65 Eliselee281275
Eliselee281275
  • 155 posts
Posted 12 July 2015 - 10:02 AM
#66 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 12 July 2015 - 10:31 AM
Might have a nice cheap exige S factory car on the way. No sport pack but new dash, 55k in I think it's chilli red? 23k
#67 e7 jmc
e7 jmc
  • 229 posts
  • Interests:Mtbing, skateboarding, parenting, musicing..........
Posted 12 July 2015 - 10:32 AM
Turbo cars Ive owned, MG metro, renault 5, Mazda 323, Escort Rs , MG Maestro, Subaru WRX, Beetle rs, Leon K1, A3
Non turbo , VX
VX supercharging imminent, soon , shortly so Ill let you know.............
#68 Eliselee281275
Eliselee281275
  • 155 posts
Posted 14 July 2015 - 04:58 PM
Cheers Jon needs to be a Elise but thanks anyway something may come up in the future that is mega quick 😉
#69 VX220BOB
VX220BOB
  • 625 posts
Posted 14 July 2015 - 06:20 PM
A standard NA is mega quick compared to an Elise S2 as you are aware of, hence super charging your Elise to try and keep up.
#70 Eliselee281275
Eliselee281275
  • 155 posts
Posted 14 July 2015 - 06:25 PM
Bob you dick 😂😂😂 coming out for blast tonight ?
#71 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 15 July 2015 - 12:37 PM
Fit the standard airbox to virtually eliminate SC noise..
I will have to try that. Does anyone have a spare na airbox for me to buy to test? I have a large cone filter at the moment & if it doesn't lose too much power the mod may help me at the quieter circuits.
Is there a NA airbox mod thread? I can't find it...
i have been working on an airbox to fit back where it originally went, as my ECU and charge cooler pump are there it required some modding.
However during testing, there was NO reduction in power, and honestly you would not know the car is supercharged it cut all the wine, and that is with half the box cut off. Also for reasons unknown to me, it made the exhaust quitter too???
#72 Rosssco
Rosssco
  • 4,185 posts
Posted 15 July 2015 - 04:39 PM
The size of the NA airbox and filter looks like it is well up to ~300bhp, especially with some removal of the lower half of it..
Did you just use a section of intake hose to go from the airbox to the throttle body Stuwy, or do the angles not work..?
#73 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 16 July 2015 - 12:21 PM
because the angle of the throttle body is pointing down on the m62 charger the biggest challenge has been connecting the air box to the TB.
with the airbox almost halved fitting it in the space is not really an issue anymore, needs to be placed from the wheel arch though.
to mount it I drilled a hole though a superfluous piece of plastic and cable tied it to the chassis upright that connects the rear sub frame to the roll over bar.
once I am happy with it (been in and out a few times) I will post up pics of what I did and how, needless to say due to my complete "that will do" attitude and the fact I know nothing means it wont be acceptable for more people :lol:
"does it work, yes, does it look pretty, no... I could spend more time making it look much better or spend more cash tiding it up.. fcuk it. It works"
Edited by Stuwy, 16 July 2015 - 12:24 PM.
#74 Rosssco
Rosssco
  • 4,185 posts
Posted 16 July 2015 - 12:36 PM
Cheers.
I was just planning on mounting it in the standard location, with the standard brackets, and opening up the lower half to ensure plenty air flow (chopping a big chunk out basically)..
#75 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 16 July 2015 - 01:13 PM
the issue with the standard positioning for me is my charge cooler pump and ECU are in the way.. also the air box points up and the TB points down so matching up is harder, off the standard bracket you can mount it lower and even spin it round if you cut enough from the bottom
#76 Rosssco
Rosssco
  • 4,185 posts
Posted 16 July 2015 - 01:39 PM
Cool. Both of those are not a issue for me, as they're located elsewhere, but will have a trial fit and see..
#77 Nev
Posted 16 July 2015 - 02:16 PM
I really doubt it TBH, based on my and other people's experience. I would be willing to bet that 2 panels and larger inlet pipework would yield power. Almost for free too, worth trying it like I did with a home made contraption.
#78 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 16 July 2015 - 02:46 PM
I don't want more power, just cleaner air
#79 Rosssco
Rosssco
  • 4,185 posts
Posted 16 July 2015 - 03:04 PM
I don't have experience of using one in this application, but doesn't it use the same filter size as the turbo, and therefor DH intake box?
I think the primary restriction on the standard NA setup is probably the weird flattened TB - airbox pipe.
#80 techieboy
Posted 16 July 2015 - 03:16 PM
NA airbox is bigger and better flowing than the turdo's. It's from a V6 Vectra.
    Bing (1)
