Bad Misfire While At High Load
#41
Posted 30 May 2016 - 08:58 AM
#42
Posted 30 May 2016 - 12:41 PM
#43
Posted 30 May 2016 - 03:38 PM
#44
Posted 30 May 2016 - 04:29 PM
#45
Posted 31 May 2016 - 05:17 AM
#46
Posted 31 May 2016 - 07:01 AM
It might possibly be that your fuel pump is getting tired or can't draw enough current.
Edited by Nev, 31 May 2016 - 07:01 AM.
#47
Posted 31 May 2016 - 08:05 AM
#48
Posted 31 May 2016 - 12:21 PM
simple test for the injectors; if they're baby blue with EV1 plug then they're VXR, black with EV1 then they're turbo.
#49
Posted 05 June 2016 - 08:47 AM
#50
Posted 05 June 2016 - 09:02 AM
what about the spark plug electrode gaps ?
might be worth closing the gap up to 0.8mm
#51
Posted 05 June 2016 - 09:18 AM
#52
Posted 05 June 2016 - 09:24 AM
#53
Posted 05 June 2016 - 09:33 AM
#54
Posted 05 June 2016 - 09:34 AM
#55
Posted 05 June 2016 - 10:15 AM
#56
Posted 05 June 2016 - 01:41 PM
My previous sc vx and this one has always done a little pop when switch off and never had issue before, it only smells of fuel, when it misfires, other than then it runs perfectly. Coil pack replaced, injectors have always worked perfectly before, lambda sensor would show a fault codes surely? What do you mean by ion sending? The fault happens the second the revs rise to around 3.5 krpm particularly at high load even when the engine is still warming up so intake temps wouldn't have chance to get too high surely? There's only a map sensor as far as I know so have no way to check this? Bit odd there isnt a temp sensor in the manifold as well? I'll check the coolant flow in the tank but other than that is there anything else I can look at? Thanks DanIf it stinks of fuel its running rich Does the exhaust give a little pop when you switch off So causes fuel not igniting or to much fuel Spark plugs Coil pack Possibly ion sending picking up somthing high temps ? Is your charge cooler working ? Lambda sensors Correct injectors from mapping ?
#57
Posted 05 June 2016 - 02:28 PM
#58
Posted 05 June 2016 - 02:32 PM
#59
Posted 05 June 2016 - 02:54 PM
Ion sensing http://www.delphi.co...ignsys/igncoils The popping is a sure sine the car is running far to rich Take a pic of your spark plug and post it please Injectors can fail and dump to much fuel in That popping is not a good sign and you may end up bore washing the cylinders A faulty lambda will give the wrong info and can cause rich running or Lean running Lambda do fail on supercharged carsMy previous sc vx and this one has always done a little pop when switch off and never had issue before, it only smells of fuel, when it misfires, other than then it runs perfectly. Coil pack replaced, injectors have always worked perfectly before, lambda sensor would show a fault codes surely? What do you mean by ion sending? The fault happens the second the revs rise to around 3.5 krpm particularly at high load even when the engine is still warming up so intake temps wouldn't have chance to get too high surely? There's only a map sensor as far as I know so have no way to check this? Bit odd there isnt a temp sensor in the manifold as well? I'll check the coolant flow in the tank but other than that is there anything else I can look at? Thanks DanIf it stinks of fuel its running rich Does the exhaust give a little pop when you switch off So causes fuel not igniting or to much fuel Spark plugs Coil pack Possibly ion sending picking up somthing high temps ? Is your charge cooler working ? Lambda sensors Correct injectors from mapping ?
#60
Posted 05 June 2016 - 05:21 PM
Bing (1)
