Bad Misfire While At High Load
#81
Posted 12 June 2016 - 05:50 PM
#82
Posted 25 June 2016 - 07:16 PM
#83
Posted 25 June 2016 - 08:25 PM
P0300 has been reported earlier as a defect coilpack.
#84
Posted 26 June 2016 - 06:13 AM
#85
Posted 26 June 2016 - 06:37 AM
#86
Posted 26 June 2016 - 07:42 AM
#87
Posted 26 June 2016 - 03:49 PM
#88
Posted 26 June 2016 - 03:59 PM
#89
Posted 26 June 2016 - 04:19 PM
think idle should be 0.5v
take no notice of the above message
have seen it go to 0.8 at times
#90
Posted 26 June 2016 - 04:25 PM
#91
Posted 26 June 2016 - 04:27 PM
What you say makes sense. Just if you've exhausted the obvious options it's about the only other thing I can think of. You'll get there eventually and it'll be something obvious.lThanks bargi, but I thought the error code would be specific to a cylinder, ie the number on the end would be 1 - 4, this has a zero which is a multi cylinder misfire, so an injector shouldn't be at fault? Be interested if anyone can answer my question about the lambda output at idle? Thanks
#92
Posted 26 June 2016 - 04:30 PM
im beginning to think there could be a compression issue with this one
#93
Posted 26 June 2016 - 05:13 PM
#94
Posted 26 June 2016 - 07:27 PM
#95
Posted 26 June 2016 - 07:29 PM
#96
Posted 27 June 2016 - 05:40 PM
#97
Posted 27 June 2016 - 07:38 PM
That's interesting, how did you know if it was stuck open or closed? I've only had the mil light on the dash come up twice and only been able to see a code once.When i had a sticky injector it would throw two codes dependant on when it stuck. Stuck open would create a general misfire code and stuck closed created a cylinder shut down code. But mine started out as fine on idle and low to mid speed but misfired at high revs/speed then it gradually got worse over a couple of months and would send the car into limp mode at anyghing over 2k revs
#98
Posted 01 July 2016 - 09:38 AM
#99
Posted 02 July 2016 - 08:07 AM
#100
Posted 02 July 2016 - 08:46 AM
Injector cleaner??
