Track Day Rubber
Posted 01 January 2017 - 08:36 PM
Posted 01 January 2017 - 08:40 PM
Posted 01 January 2017 - 08:45 PM
Posted 01 January 2017 - 08:49 PM
Edited by CHILL Gone DUTCH, 01 January 2017 - 08:50 PM.
Posted 01 January 2017 - 08:56 PM
Posted 01 January 2017 - 09:29 PM
I've had my R888R shaved from new, so from 5mm to 3mm and they last longer than running them from 5mm. I can get 5 x 45 min races and 5 x 30 min qualis from the rears and 6 out of the fronts. That's one more than leaving them at 5mm.Over the last 12 months I've been on ZZRs, RSR, and the R888R I think for out and out grip R888R is the best but they only lasted 2 track days ( rears ) ZZRs seem very Consistant and grip very well and don't seem to wear heavy RSR is by far the best value for money and I'm keen to try them again with my recent setup they also wear very well and are only £250 a set
Posted 01 January 2017 - 09:31 PM
Posted 02 January 2017 - 01:13 AM
For the fronts on the RSR is there a consensus between 205/45 and 205/50. Rolling radiuses are minimally effected with either but is ride quality different (better?) or turn in (worse?) with the slightly taller sidewalls of the 50 profile?
Posted 02 January 2017 - 07:45 AM
Posted 02 January 2017 - 07:52 AM
Posted 02 January 2017 - 08:39 AM
I´ve been running 205/50-16" RSR on the front and 235/40-17" Nankang NS-2R (TW180) rear for two seasons. Can get a little slippery in the rear when I´m doing longer stints (+20min) but a nice amount of grip for almost no money at all.
This year I´m trying V70A in 205/45-16" and 225/45-17" medium compound.
Posted 02 January 2017 - 09:36 AM
Interesting. Quick Google as to how it works. Otherwise would have thought it sounded like BS.I've had my R888R shaved from new, so from 5mm to 3mm and they last longer than running them from 5mm. I can get 5 x 45 min races and 5 x 30 min qualis from the rears and 6 out of the fronts. That's one more than leaving them at 5mm.Over the last 12 months I've been on ZZRs, RSR, and the R888R I think for out and out grip R888R is the best but they only lasted 2 track days ( rears ) ZZRs seem very Consistant and grip very well and don't seem to wear heavy RSR is by far the best value for money and I'm keen to try them again with my recent setup they also wear very well and are only £250 a set
Posted 02 January 2017 - 10:10 AM
Interesting. Quick Google as to how it works. Otherwise would have thought it sounded like BS. �
Place in Tadworth does them for £10 each. Remove from wheel, shave, refit and balance.
Posted 03 January 2017 - 09:14 PM
I'd be very interested in trying the AR1s - where did you get the 195/50/16s from?I decided to try the Nankang Ar1 when the r888's wore out and must say I was very impressed, very similar in terms of grip and feel, same triangle indicators on the sidewall to aid making sure your at the right pressures etc and the Ns2r is also worth considering and equal to Federals.
Posted 04 January 2017 - 08:27 AM
Had this reply from Nankang; "Hi Neil, Thank you for your message. The AR-1 has been delayed slightly from the original expected date of Q3-Q4 to Feb/March 2017. There are only a select number of authorised motorsport dealers to protect the price. Demon Tweeks would be the best option at this moment in time, they are the biggest motorsport stockist we supply in the UK. Keep posted on our social media Kind regards" So it looks like a waiting game as far as a 16" front is concerned.I'd be very interested in trying the AR1s - where did you get the 195/50/16s from?I decided to try the Nankang Ar1 when the r888's wore out and must say I was very impressed, very similar in terms of grip and feel, same triangle indicators on the sidewall to aid making sure your at the right pressures etc and the Ns2r is also worth considering and equal to Federals.
Posted 04 January 2017 - 09:52 AM
has anyone had any experience of the
Federal FZ-201 Road - Track Tyre
Posted 04 January 2017 - 09:55 AM
The track day road/track tire market has certainly changed over the 21-18 months so think this is a good topic
Posted 04 January 2017 - 01:31 PM
fz-201 , sizes don't work for us , iirc
Posted 04 January 2017 - 02:03 PM
Edited by chris_uk, 04 January 2017 - 02:04 PM.
Posted 04 January 2017 - 02:06 PM
if we are talking 595rsr - , then you are wrong
