#64
#61
Posted 21 March 2017 - 05:36 PM
#63
Posted 23 March 2017 - 01:15 PM
Check the height of the engine mount before fitting compared to the old/original ones.
The newer ones can be different in size (shorter mostly), which can cause the engine to 'sit' on the front/back mounts too much overloading those.
Should be a few threads on here about this issue experienced by several people.
#64
Posted 23 March 2017 - 02:09 PM
Edited by ditonics, 23 March 2017 - 02:09 PM.
#65
Posted 23 March 2017 - 02:14 PM
#66
Posted 23 March 2017 - 02:17 PM
The rest of the bits are on the floor;) Fuel filter, rear HCBs and broken engine mount done.I have that press Although your friend has forgot to bring the bottle jack round for it!
#68
Posted 27 March 2017 - 01:35 PM
are you planning on replacing the KKK turbo with a different manifold and turbo?
#69
Posted 27 March 2017 - 04:43 PM
Long term looking at the gtx2867R.are you planning on replacing the KKK turbo with a different manifold and turbo?
#70
Posted 27 March 2017 - 07:49 PM
#71
Posted 27 March 2017 - 09:24 PM
#72
Posted 27 March 2017 - 09:30 PM
It will all be going on a second fully forged engine. Long term project.Has your vxr got upgraded internals?
#73
Posted 27 March 2017 - 09:31 PM
Still doing home work, will look into it.Have you considered a 71HTA instead? Spools faster than a normal GTX28 and makes power similar to that of a GTX30, plenty running over 500bhp on these now and only a couple of hundred more expensive than a normal GTX28.
#74
Posted 28 March 2017 - 09:23 AM
holset turbos over anything else on the market
#75
Posted 28 March 2017 - 09:28 AM
Yeah if you don't want any power until 5k rpm.
#76
Posted 28 March 2017 - 09:53 AM
Out of interest, how come? I noted they seem to be relatively cheap compared to the Garrett turbos, and most seem to be twin scroll. I thought they were generally better for larger capacity engines.
#77
Posted 28 March 2017 - 10:05 AM
Holsets are mainly from large capacity diesel and tractor engines. They're well built and reliable but on a piddly 2.0L engine they're laggy as hell.
You'd get quicker spool from one of the china copy GT30 turbos from ebay.
#78
Posted 28 March 2017 - 12:45 PM
Yeah that's the impression I had of them - they are physically pretty large and undoubtedly 'robust' looking..
#79
Posted 28 March 2017 - 12:58 PM
I have to say I can't fault my GTX3071, after 7 years it's still going strong. Also my Tial MVR44 was been faultless.
Having said that, in your "new build position" I would still consider a variable geometry or twin scroll turbo too.
#80
Posted 28 March 2017 - 01:19 PM
