to add more confusing I can be sure this isn't just happening at one rolling road as it would appear the ecu can pulling th timing out hence the power isnt correct.
Now based on how may people have had their cars mapped this clearly isnt happening often but can effect power on some cars but only on the dyno. Dont be thinking your car is making more power with a fuse out, its just sometimes on the dyno.
When I was at Courtney Sport they said well thats a good dyno run with no ignition you literally have none. I thought umm thats odd im sure my last map had some timimg as it made some 300ft/lbs which u wont get from no timing LOL
Anyway the power figure was down but CS didnt mention the ABS fuse
I went to rabbid and dyno, again the figure was lower than last time i was there and 20bhp down from CS reading some 3 days earlier. He said dont worry all dyno read different lets just start from here as a base figure.
Tweeked the map and gain no power, even though he mapped in plenty of timing plus boost still no more power. Shock his head and said huhh Ive seen this before not common but some astra z20let have an issue with the ABS on the rollers.
Where you ABS fuse? Remove it.
So we did, left the map alone and instantly pulled 40bhp or so more. He smiled and said told u!
I have dyno here before and made results without removing the fuse and was fine, but this time and at CS the fuse need to be pulled. No idea why
He did say its something to do with the dyno and on the road the power would still be there, its the car getting confused
