I'm surprised as well. It's a very high torque for just over 3k, that's why it would be interesting to see the whole dyno sheetMe too. Logically i question the original readings.I'm thoroughly confused by this thread.
Vxt Dyno Shock!
#81
Posted 22 March 2017 - 11:48 PM
#82
Posted 23 March 2017 - 10:13 AM
The whole sheet is on the first page... its a sh*t plot though
#83
Posted 23 March 2017 - 10:46 AM
Ignore that first one its not correct, that was the very first one that was done its totally inaccurate.
I have the correct one that i'll post later.
#84
Posted 23 March 2017 - 11:08 AM
All sounds a bit odd to me, surely someone can clarify the ABS issue after a decade of tuning these cars?
How does it actually feel to drive now, much improved from the last map?
#85
Posted 23 March 2017 - 11:48 AM
Well the first reading didn't seem accurate (the reading i posted) and the mapper (Rabbid) said it didn't look right either so said remove the fuse and see what happens once we did that the reading went from 161bhp to 231hp but torque reading was 371lbs so he then re mapped it and its now 238hp and 300lbs torque, The drive feels a lot more progressive than before, before the remap it would accelerate like a speeding bullet, then according to the dyno would slump in power then pick up again now the slump has been ironed out and it holds power throughout the rev range.
I know a lot of you can't get your head around the fuse issue and as i'm nowhere near an expert on this its literally all i can tell you.
#86
Posted 23 March 2017 - 11:51 AM
I assume the original RR results were done somewhere in Plymouth and then you went to Rabbid in Basingstoke for the mapping?
#87
Posted 23 March 2017 - 12:17 PM
It was all done in Plymouth Rabbid re maps for AK Motorworx remotely.
#88
Posted 23 March 2017 - 12:39 PM
I can explain the ABS thing with logic
The only link between ABS module and ECU is the speed signal , the same speed signal that goes to the instrument cluster
So the the power is cut by the ecu because of the speed
ABS fuse out , speed signal gone
I have looked over the circuits because I am genuinely interested in this stuff,
given all the evidence this is the only conclusion
#89
Posted 23 March 2017 - 12:43 PM
This doesn't make sense because the speed signal comes from the nearside rear wheel sensor which would be giving the correct speed reading??
#90
I think lb ft is getting confused with nm
original reading shows 261 lb ft which is 352 nm
http://www.convertun...om/lb-ft/to/N-m
300nm seems correct for 230 hp
#91
Posted 23 March 2017 - 12:52 PM
the speed signal from the sensor still has to go via the ABS control unit prior to hitting the powertrain controller.
#92
Posted 23 March 2017 - 12:58 PM
This sounds exactly like what i was told.
#93
Posted 23 March 2017 - 12:59 PM
#94
Posted 23 March 2017 - 01:01 PM
You have to remember that original reading was completely wrong. It can almost be ignored as it wasn't a true reading. didn't know that at the time but we do now.
The only readings that came from the dyno are in lbs/ft
#95
Posted 23 March 2017 - 01:03 PM
This is being made complicated. When others have their car on a RR do they have to take the abs fuse out too? Kinda curious now.
To find out i'd suggest whoever is planning on a dyno run in the future do one with the fuse in and one with the fuse out and see if it makes a difference.
#96
Posted 23 March 2017 - 01:04 PM
Mine is going to Rabbid on the 4th so i'll get 2 readings with fuse in and fuse out.
I have the front near side sensor disconnected will this have the same effect as removing the fuse for this purpose?
#97
Posted 23 March 2017 - 01:05 PM
#98
Posted 23 March 2017 - 01:07 PM
So many people have had their vx on a RR i would of thought it would been known already.
I expect is has something to do with the specific RR as I've had an accurate reading with the ABS connected.
#99
Posted 23 March 2017 - 01:13 PM
None of my clients have ever had to disable ABS when using my maps which are VX220 optimised.
The speed signal is part of the cruise control logic and automatic gearbox torque limiter controls. Both systems found on Zafira ECU software ....
#100
Posted 23 March 2017 - 01:58 PM
Honestly I don't know theres nothing more I can add or say to help i'm a mapping expert or dyno expert.
The simple fact of the matter is my fuse had to be removed to give an accurate dyno reading it didn't have to be disabled to use a map just to give a correct dyno reading. Maybe Andy_VX can ask Rabbid on the 4th as to why.
