Posted 02 November 2005 - 12:13 PM
Posted 02 November 2005 - 02:04 PM
From my research either 4 4 or 5 5 is a good setup for the Ecotec. I am using 5 5.For the pressure sensor setup,the sensor number in-out is 1 1 ??
Upward pointing.Throttle sensor output voltage is with the arrow upward or downward(0v closed or 0v fully open)??
You will see a black ground cable connected to one of the ECU mounting points (top left). This is the ground to useWhere you connected to the ECU ground??
Edited by speedster, 02 November 2005 - 02:07 PM.
Posted 02 November 2005 - 03:49 PM
Sure!!Your welcome
Let me know how you get on
Edited by cicastol, 02 November 2005 - 04:19 PM.
Posted 02 November 2005 - 04:16 PM
AFAIK the knock sensor is a one wire only sensor and is located on the exhaust manifold side of the engine, coolant reservoir side. If I am wrong wonder what I have connected to?Another little question,where did you connected the knocking sensor??
I've seen that from the connector of the knocking sensor(placed under the intake manif.) there are 2 wire,1green and 1 red,wich one you connected??
Edited by speedster, 02 November 2005 - 04:16 PM.
Posted 02 November 2005 - 04:25 PM
I'm sure of the knocking sensor because it is listed on my TIS2000 cd(with wiring diagram missing...) on the na is located under the intake manif. and fixed aginst block,it has 2 wire,white red and after a connector they become green and red!!AFAIK the knock sensor is a one wire only sensor and is located on the exhaust manifold side of the engine, coolant reservoir side. If I am wrong wonder what I have connected to?
Posted 02 November 2005 - 07:51 PM
OK, I will have to check it out.I'm sure of the knocking sensor because it is listed on my TIS2000 cd(with wiring diagram missing...) on the na is located under the intake manif. and fixed aginst block,it has 2 wire,white red and after a connector they become green and red!!
Posted 02 November 2005 - 08:41 PM
Now i looked your's photo,probably you attached to the wire of the ignition noise suppressor,it looks like a transistor in a TO 220 packageOK, I will have to check it out.I'm sure of the knocking sensor because it is listed on my TIS2000 cd(with wiring diagram missing...) on the na is located under the intake manif. and fixed aginst block,it has 2 wire,white red and after a connector they become green and red!!
Posted 02 November 2005 - 08:57 PM
Kocking sensor looks like this:
http://www.bosch-mot...ensors/KS-R.pdf
with standard manifold is really hard to see it,you need to remove the undertray to get access![]()
P.S.probably is not a good idea to connect the knocking sensor,because the long wire you need to connect to the safc2 can pick up EMC and noise so could trigger in the ECU a false knock detection,probably need to use at least a shielded cable if you want to connect it!
Edited by speedster, 02 November 2005 - 09:09 PM.
Posted 02 November 2005 - 09:25 PM
Probably during this weekend,now we must search for the correct sensor number(i've seen on J-body too many variations,4-4, 5-5,4-0 ecc.When are you installing the SAFC-2?
Posted 02 November 2005 - 10:05 PM
I reckon the green wire is the sensor output.our MAP is a standard 1bar sensor from Delco now i would like to know what is the japan car listed in the manual that use this sensor!!
Edited by speedster, 02 November 2005 - 10:53 PM.
Posted 03 November 2005 - 08:59 PM
Edited by speedster, 03 November 2005 - 09:02 PM.
Posted 06 November 2005 - 08:00 PM
Edited by speedster, 06 November 2005 - 08:04 PM.
Posted 06 November 2005 - 08:03 PM
Edited by speedster, 06 November 2005 - 08:05 PM.
Posted 06 November 2005 - 08:10 PM
Posted 06 November 2005 - 10:36 PM
I've not yet mounted the safc,instead i've mounted a rear CF wing this weekendIn trying to determine the Sensor Number for the SAFC-2 configuration
Posted 06 November 2005 - 11:06 PM
Hi cicastol. Yes, it would be nice to get it from Apexi themselves. At this stage I still don't understand what the actually setting does or is forFor me the only hope to know the correct safc number for the GM-Delco 1 bar MAP sensor is to send an e-mail to Apexi,but i could'nt find any email on their website... or find a japan car equipped with a similar or the same MAP sensor listed in the installation manual..!!
Posted 07 November 2005 - 10:52 AM
Posted 07 November 2005 - 01:01 PM
is there any wiring for these units for the z20let turbo engines? wouldnt mind having a play.
would it kill me car though?
Posted 07 November 2005 - 03:01 PM
Posted 07 November 2005 - 04:02 PM
Edited by speedster, 07 November 2005 - 04:13 PM.
