stop, I don't understand that wordVocky can you please stop mod'in
your gonna cost us a small fortune !!!
2.4 vvt with itb's and 275 bhp is on my wish list
Posted 22 March 2008 - 08:46 AM
Posted 10 December 2008 - 02:38 PM
Posted 10 December 2008 - 03:05 PM
Posted 11 December 2008 - 12:27 PM
Posted 12 December 2008 - 10:41 PM
Posted 28 October 2009 - 02:23 PM
Posted 28 October 2009 - 02:32 PM
updates;
About June 2008 I replaced the kevlar clutch plate with a Helix sprung M32 item, much better as it required no 'bedding in'.
Today I replaced the M32 gearbox internals with a 4.17 V2 set, this makes my M32 gearbox equivalent to a 4.55 F23![]()
I have ordered a z22se M32 lightened flywheel, so the slave cylinder spacer is no longer required as the flywheel is 15mm nearer the gearbox.
So the M32 6 speed is fast becoming an 'off the shelf' conversion, only the gear lever to go
Posted 28 October 2009 - 09:27 PM
Posted 29 October 2009 - 11:10 AM
you can use the original F23 cover plate but you must use a M32 clutch disc and slave cylinder, but some flywheels are designed for the astra vxr clutch which is bigger than the F23 clutch, so really depends on which flywheel you use.
The F23 flywheel isn't really deep enough, so you would require a M32 version![]()
The vxT could use the standard dual mass flywheel (DMF) and clutch from the astra vxr.
The z22yh uses an eight bolt flywheel so the DMF won't fit the z22se engine as it uses a six bolt flywheel.
Posted 29 October 2009 - 11:23 AM
Posted 29 October 2009 - 11:28 AM
Posted 29 October 2009 - 11:38 AM
Vocky what are your reasons for changing the FD on the 6 speed box? Find the ratios really good on mine - if my limiter was higher maybe this would be something to work with?
Posted 29 October 2009 - 11:39 AM
Edited by siztenboots, 29 October 2009 - 11:41 AM.
Posted 29 October 2009 - 11:46 AM
Posted 29 October 2009 - 12:00 PM
Posted 29 October 2009 - 12:02 PM
Posted 29 October 2009 - 12:08 PM
I have no current plans for phase 3, so the 2.4 is on hold2.4 vvt with itb's and 275 bhp is on my wish list
wondering about the 2.0l LNF
Posted 29 October 2009 - 12:16 PM
Posted 29 October 2009 - 12:30 PM
the main reason I fitted a 6 speed gearbox was for the ability to lower the final drive ratio
the corsa vxr 4.17 V2 has very good ratio's, similar to a 4.55 F23
the 4.17 V1 is as rare as hens teeth, I know of only one for sale secondhand (in Germany) and the guy wants 'new' money for it![]()
£2k for a new 4.17 V1 is quite tempting, but seriously I have better things to spend £2k on than a gearbox
Posted 29 October 2009 - 01:06 PM
Edited by vocky, 29 October 2009 - 01:08 PM.
