6 Speed 2.2
99 replies to this topic
#41 vocky
Posted 04 February 2008 - 12:06 PM
I forgot to update this thread :rolleyes: the conversion went well until the first test drive when the clutch failed as I tried to leave my garage, this turned out to be the uprated clutch cover was a different depth than the standard clutch cover which caused the slave cylinder to 'pop' it's seal :angry2: anyway with the original clutch cover fitted all was well again :D after the first test drive it was apparant the gear lever reverse gate needed further work, so I modified the gearlever to create a push down reverse gate. then I managed to locate a turbo M32 box at the breakers, so I stripped the car once again and the M32 internals were swapped over, now I have a 3.94 final drive ratio B) the kevlar clutch finally decided to 'bed in' and all I can say is :groupjump: 1st gear now = 34mph 2.2 = 36mph vxt = 39 mph 2nd gear now = 60mph 2.2 = 64 mph vxt = 69 mph 3rd gear now = 87mph 2.2 = 95 mph vxt = 104 mph 4th gear now = 121mph 2.2 = 133 mph vxt = 145 mph 5th gear now=147mph 2.2 = 163 mph vxt = 178 mph 6th gear now = 173mph
#42 RobNA
RobNA
    RobSC :)
  • 2,856 posts
Posted 04 February 2008 - 02:08 PM
thumbsup Has it made a huge amount of difference to the acceleration/feel of the car? and a better motorway cruising mpg too thumbsup
#43 vocky
Posted 04 February 2008 - 02:43 PM
acelleration is superb, I highly recommend lowering the final drive ratio B) these are the max speeds for a F23 with the 4.17 fd ratio, as you can see 1st and 2nd are the same but the other gears are better with the M32 :D 1- 34 2- 60 3- 90 4- 126 5- 155
Edited by vocky, 04 February 2008 - 02:44 PM.
#44 wirestriker
wirestriker
  • 36 posts
Posted 20 March 2008 - 10:54 AM
Hello Vocky, very nice job :o I found a perfect M32 box for my VXT, it comes from a Z20LER Astra H, with perfect ratios: 3.94 FD, so 6th will be just a little bit shorther than my F23 5th :). I read you changed driveshafts and gearbox mounts on your 2.2, do you think these parts are needed even for a VXT? I searched a lot but I cannot find the answer. Thanks a lot
#45 VIX
VIX
  • 9,497 posts
Posted 20 March 2008 - 12:48 PM
B*gger, so that's something else for next year's mods list!! Nice job! thumbsup Imnotworthy
#46 MEAGY
MEAGY
  • 1,374 posts
Posted 20 March 2008 - 02:33 PM
Thanks a lot
you need to do & use everything that vocky has done! thumbsup
#47 vocky
Posted 20 March 2008 - 05:32 PM
the 2.2 and turbo vx220's share the same drivetrain (apart from the diff) so the conversion is the same. as you are starting off with an astra M32 it will have the correct passenger (alloy) gearbox mounting bracket fitted, if not they are only £22 new from the vauxhall dealer. The passenger mount is in two halves, one half is alloy (vauxhall M32) and the other half is metal (lotus europa S). you will need a pair of 2007> lotus europa S driveshafts, passenger gearbox mount (metal) and rear gearbox mount (alloy). These cost £680 inc vat. I would advise to fit the dual mass flywheel to your vxT, this sorts the clutch. You could use the standard vxT flywheel and fit the M32 clutch plate (with a spacer on the slave cylinder) but your gearbox will have a shortened lifespan due to the extra vibrations caused by using an 'unsprung' clutch plate. I would also advise using the 2007> lotus europa S gear lever assembly (£500 + vat) this has the pivot assembly built in so would be a direct swap, then use the vx220 cables. I have since modified the gearlever to create a 'shortshift', this makes the gearchange feel much better rallly
#48 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 20 March 2008 - 07:18 PM
any pictures on that vocky and what did you do thumbsup
#49 vocky
Posted 20 March 2008 - 07:36 PM
if you cut off the lug holding the cable ball joint and weld it higher up the lever the 'throw' is reduced. only downside is if you weld it too high you will have to trim the centre console or the gear cable will hit the console :rolleyes:
#50 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 20 March 2008 - 07:51 PM
so how much do you move it up ?to be on the safe side vocky
thanks thumbsup
Edited by crazyfrog, 20 March 2008 - 07:53 PM.
#51 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 20 March 2008 - 07:54 PM
Edited by crazyfrog, 20 March 2008 - 07:56 PM.
#52 vocky
Posted 20 March 2008 - 08:09 PM
I fitted a new shorter lug, with a new ball joint, above the original, this caused the cable problem. That was simply fixed with a larger cut out and a new leather gaiter. so I would say no more than 5-8mm higher and make the lug shorter too, you can adjust the cable length to retain the central lever position.
#53 MAXR
MAXR
  • 2,719 posts
Posted 21 March 2008 - 07:00 AM
Vocky, It sounds like you're doing full open heart surgery on your gearbox, top stuff! I'm just replacing my na gearbox with a Zafira's 4.17 gearbox which should be done within a couple of weeks, so nothing fancy. What oil will you be using in the box? Also my linkage gets stiff when the engine is hot, my exhaust is wrapped too. New cables are £400 for a pair. Is it possible to lubricate the existing ones properly or is there a cheaper fix? MAXR
#54 vocky
Posted 21 March 2008 - 08:21 AM
I always use the £15 a litre vauxhall transmission fluid, it used to be a red coloured oil but is now clear. If your linkage cables have melted internally then there is little you can do to repair them, maybe a silicone oil/grease :unsure: I would personally buy a pair from a 'breakers/salvage company' as they would be quite cheap compared with the new price.
#55 wirestriker
wirestriker
  • 36 posts
Posted 21 March 2008 - 08:25 AM
Thanks for replying Vocky, all is clear now. Maybe Europa's driveshafts are the same of other VX's? You know, finding them in a scrappy will be cheaper... ;)
#56 vocky
Posted 21 March 2008 - 08:42 AM
the driveshafts are M32 six speed only :rolleyes:
the M32 diff is slightly nearer the lefthand wheel so that shaft is shorter and the other shaft longer thumbsup
this is how my gearlever looks now
#57 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 21 March 2008 - 11:16 PM
Cool! Well done vocky! Be interesting to see if the gearbox and clutch mod combined with the balance shafts removal has any long term effect. What are the vibration levels like? Any differences with the new box and clutch? thumbsup Steve
#58 Baron Von Scubadaddy
  • 6,644 posts
Posted 21 March 2008 - 11:39 PM
Vocky can you please stop mod'in your gonna cost us a small fortune !!! Imnotworthy Imnotworthy Imnotworthy Imnotworthy
#59 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 22 March 2008 - 12:07 AM
too many beers voky i am not a mechanics but a business man well done and hope i can see you one day and meet you did a good mod today and honestly i am pretty chav :rolleyes: :rolleyes: specially when its not my field keep on the good work and we all trying to digest your so cool nonsense(of course to us) got up at 7.00 am this morning to do my car and it was good now 1 pm and just finnish had a good business wise but need a holiday lol chinky chinky
#60 vocky
Posted 22 March 2008 - 08:16 AM
thumbsup
Steve
balancer shafts - there is a guy in the usa who has done over 50,000 miles without balancer shafts, no issues Imnotworthy
6 speed gearbox - I used a 'sprung' clutch plate from a honda crx, so will have no issues with vibration damaging the gearbox :D
vibration - I have fitted both F+R uprated engine mounts so have the minor vibration at tickover which every vx220 has when these mounts are fitted :rolleyes:
the only downside to the 6 speed conversion was bedding in the kevlar clutch, being unable to unleash the engines power was depressing to say the least :beat:
At my Total Vauxhall photoshoot they noticed the engines quick throttle response without me even mentioning it, I'm just waiting for my underdrive crank pulley to arrive from the states so I can also fit the lightened alternator pulley I have, they should help the quick throttle response some more :lol:
