the gearbox arrived this morning and it's a M32What box is it F40, M32 etc...
Very brave project (not that the others weren't)
6 Speed 2.2
#21
Posted 09 November 2007 - 08:50 AM
#22
Posted 09 November 2007 - 09:10 AM
#23
Posted 09 November 2007 - 11:30 AM
What box is it F40, M32 etc...![]()
if you carry on like that you might need a 7 speed gear box vocky lol
good work and good input for us
wish i was a mechanics to do more on the vx
#24
Posted 09 November 2007 - 01:31 PM
if you carry on like that you might need a 7 speed gear box vocky lol![]()
just get andyroooooo to teach you
#25
Posted 09 November 2007 - 03:21 PM
[/quote]
[/quote]
very good indeed I'll have to feed him and you as well
oups i forgotten you only work for liquid
Edited by fab72, 09 November 2007 - 03:22 PM.
#26
Posted 10 November 2007 - 02:21 PM
Will be watching this thread closely, I'd quite like 6 gears mesself
#27
Posted 11 November 2007 - 08:58 AM
just get andyroooooo to teach you![]()
Im a long way from swapping gearboxes!
Wouldn't mind the VW DSG box myself, had one in my Golf and what a gearbox that was. However, this is still an impressive extension to the VX mod range. Keep up the good work vocky, paving the way for the rest of us
#28
Posted 11 November 2007 - 06:08 PM
#29
Posted 11 November 2007 - 06:50 PM
The OBX items ?
after some research I realise not to touch an obx diff, it seems they are made very cheaply in a far eastern country, probably from choclate
so the quaife atb diff would be the only option, still it would be a very easy swap on the M32 box
Edited by vocky, 11 November 2007 - 06:51 PM.
#30
Posted 12 November 2007 - 08:26 AM
The OBX items ?
after some research I realise not to touch an obx diff, it seems they are made very cheaply in a far eastern country, probably from choclate![]()
will you be doing many miles in the vx?
if so i can whole heartedly recomend a Plate type diff (gripper, tran-X etc). As Ive found Torsen diffs to be snatchy and to not really be of much use.... but it is a personal preference really.
#32
Posted 21 November 2007 - 12:58 PM
#33
Posted 21 November 2007 - 01:17 PM
#34
Posted 03 December 2007 - 04:41 PM
And so it begins......
#35
Posted 04 December 2007 - 03:56 PM
#36
Posted 04 December 2007 - 03:57 PM
#38
Posted 09 December 2007 - 12:56 PM
#39
Posted 09 December 2007 - 01:36 PM
#40
Posted 09 December 2007 - 01:40 PM
"Now available from Courtenay Sport, the Quaife ATB differential for M32 gearboxes. A direct replacement for the standard Vauxhall differential, the Quaife ATB differential transforms your car's performance, making getting the power down onto the road easier, for improved traction and driveability.
Unlike a conventional plate-style limited slip differential, the ATB diff relies on gears rather than clutch plates for its operation. That means it is much smoother in operation. Because of this, the ATB differential never locks harshly with a set pre-load of wheel slip across the driven axle, like a conventional LSD. Rather, the differential automatically biases the torque away from the spinning wheel across the axle, to a constantly varying degree, and never locks.
The Quaife ATB differential has many benefits over a standard open differential, including maximising traction and minimizing wheelspin, eliminating torque steer and snatching in front wheel drive cars compared to conventional LSD units, and a maintenance-free design which retains the standard oil lubrication.
Available now for Astra VXR (Z20LEH), Astra 1.9 CDTi, Astra H 2.0 Turbo (Z20LEL/Z20LER), Astra H 1.6 Turbo (Z16LET), Corsa VXR (Z16LER), Corsa D SRi 1.6 Turbo (Z16LEL)
Retail Price - £611 including VAT. Introductory Offers Available - Call for details. Fitting Also Available."
