you can buy these tyres cheaper at camskill 01946 518202 speak to scott
rears 225 45 R17 £69.50 inc postage and VAT
liam
Not any more!!
Posted 28 May 2008 - 04:17 PM
liam
Posted 28 May 2008 - 07:38 PM
Edited by snoopstah, 28 May 2008 - 07:41 PM.
Posted 28 May 2008 - 10:00 PM
Posted 29 May 2008 - 07:55 AM
Posted 29 May 2008 - 08:59 AM
So come on then, tell us how the 195s on the fronts are working out.....
Posted 29 May 2008 - 09:11 AM
Posted 29 May 2008 - 08:58 PM
Lynx,
Im about to order to bridgestones at £440 a set. Tell me if im doing the wrong thing and that your experiment with the F1s was a winner.
- Noble
Edited by thelynxeffect, 29 May 2008 - 09:00 PM.
Posted 29 May 2008 - 09:41 PM
Posted 29 May 2008 - 10:10 PM
Lynx,
- Noble
Posted 30 May 2008 - 07:19 AM
Posted 30 May 2008 - 07:39 AM
Really
question, but what's the insurance implication of fitting 'mis-fitting' tyre sizes?
Posted 30 May 2008 - 08:46 AM
Posted 30 May 2008 - 08:47 AM
Lynx,
- Noble
I've seen you post this £440 a few times now....
Are you mad?
Sub £400 is always the mark for Bridgestones...
>clicky<
£440 is madness
Edited by NOBLE, 30 May 2008 - 08:49 AM.
Not in the north east mate. normal prices are coming out at £524!
Edited by mcarrick69, 30 May 2008 - 08:50 AM.
Posted 30 May 2008 - 09:03 AM
Posted 30 May 2008 - 09:15 AM
Edited by Whippet, 30 May 2008 - 09:15 AM.
Posted 30 May 2008 - 11:51 AM
An wheel can typically accept a wide range of tyre widths - the sidewall simply flexes slightly in or out, depending on the width of the tyre compared to the width of the rim. If you go too far, there is the risk that the tyre can pop off the wheel at high loads, but tyre manufacturers typically specify the range of wheel widths that are acceptable/safe for a given tyre - it can be quite surprising how wide the range can be.I'm probably missing something but can't quite grasp this - how come you can fit wider tyres on the front - how do they physically fit on?
Posted 30 May 2008 - 11:59 AM
Really
Its wear and tear so it shouldnt be an implication... Lets face it, most people are running on budgets and even remoulds - now thats dangerous with this countrys weather
Posted 30 May 2008 - 12:02 PM
Another linky to this table - showing min/max tyre widthsAn wheel can typically accept a wide range of tyre widths - the sidewall simply flexes slightly in or out, depending on the width of the tyre compared to the width of the rim. If you go too far, there is the risk that the tyre can pop off the wheel at high loads, but tyre manufacturers typically specify the range of wheel widths that are acceptable/safe for a given tyre - it can be quite surprising how wide the range can be.I'm probably missing something but can't quite grasp this - how come you can fit wider tyres on the front - how do they physically fit on?
Posted 30 May 2008 - 12:07 PM
What has the wear and tear aspect got to do with it? What Convict was asking was is there any scope for insurers to imply that the wrong size tyre (or even, for that matter, wrong size wheel!) as per manufacturer specification might have compromised safety in the event of an accident, and refuse to pay out? Or should have been declared as a mod? If so then the onus is then on you the insured to argue otherwise...
Edited by timmyp, 30 May 2008 - 12:09 PM.
