Just Ordered My Goodyear Eagle F1's For Oem Wheels
#61
Posted 10 August 2008 - 07:22 PM
#62
Posted 10 August 2008 - 09:28 PM
#63
Posted 03 September 2008 - 10:55 PM
#64
Posted 07 September 2008 - 11:45 AM
#65
Posted 07 September 2008 - 04:44 PM
I'm about to get some new fronts and and looking at the goodyears too. One thing that the worries me:
Is anyone concerned that the extra width (and maybe even tread pattern) could increase the risk of aquaplaning?
I run 205 fronts without problems. Worn tyres are a big factor
#66
Posted 08 September 2008 - 08:59 AM
#67
Posted 10 September 2008 - 03:05 PM
I'm using 195's (GSD3's) and the improved braking outweighs any aquaplaning or any lesser cornering ability.
Not that aquaplaning or cornering has ever been an issue.
Just to let you know they have stopped making the GSD3's and a new pattern F1 is out but not available in 195/45/17. So better source a set now if you want them.
#68
Posted 12 September 2008 - 09:45 PM
Since the GSD makes are not long for this world, although I assume there will be a replacement at some point, has anyone tried a 195/40/R17 tyre, now that other people have established that 195 tyres do in fact fit?
I realise the sidewall will be a little smaller than the 195/45, which might mean they don't flex enough to fit them on the narrower rims, but rolling circumference will still only be 5% less than the standard tyres according to this so I wouldn't imagine that the ABS will be affected (I have it switched off most of the time anyway).
I only ask because if the 195/40 tyre fitted, there are loads of tyres available, including KU31s, which a lot of people fit on the 16/17 combo, so could prove quite a cost-effective solution...
#69
Posted 13 September 2008 - 10:25 AM
#70
Posted 13 September 2008 - 10:37 AM
Edited by timmyp, 13 September 2008 - 10:38 AM.
#71
Posted 13 September 2008 - 10:42 AM
They don't exist in the original size. Bridgestones are the only tyre available in 175/55/R17.
Oh yeah, so is it actually worth upgrading then??? Im confused and need some newbies but dont wanna kill myself.
#72
Posted 13 September 2008 - 12:10 PM
#73
Posted 14 September 2008 - 11:00 PM
#74
Posted 15 September 2008 - 12:02 PM
Same here since June.I've just fitted exactly the same tyres as "thelynxeffect" fitted at the beginning of this tread: GSD3's 225-45-17 rear and 195-45-17 front...
Positives:
Good grip in the dry
Great grip in the wet
Negatives:
Catches front plastic when turn corners that are on an incline but not badly
Soft side wall makes you have a bit more wallowing not great if you have a standard VXT shockers
If Bridgestones were cheaper I'd still be buying them but they are not so the Eagles will do for now.
#75
Posted 15 September 2008 - 09:31 PM
#76
Posted 15 September 2008 - 11:06 PM
#77
Posted 16 September 2008 - 07:22 AM
#78
Posted 23 September 2008 - 10:00 PM
#79
Posted 30 September 2008 - 10:07 PM
#80
Posted 30 September 2008 - 11:20 PM
