2.2 + Saab Head
200 replies to this topic
#61 alanoo
alanoo
  • 1,324 posts
Posted 08 September 2008 - 02:30 PM
the sandcast heads do have slightly smaller ports than the lost foam ones (unless Matts head was well ported out lol)
Just need to get my head pressure tested and it will be out forsale :D
An LSJ/Saab one ?
Just ping me if you sell one Imnotworthy
#62 vocky
Posted 08 September 2008 - 03:48 PM
Great thanks vocky, useful as ever! What could you consider to be a good price for the sand cast head? If I'm ordering something from allecotec are there any other bits I'd be wanting to get from them such as valves/bolts?
anything from £200 - £500, just depends on where you buy it from :unsure:
I would certainly get a set of standard size wasted stem valves from 'all ecotec', you could also get a set of ARP head studs, wiseco pistons, comp cams, really depends how much you want to spend :rolleyes:
what are the parts like from that allecotec place? Looking at the cams really
comp cams are a well known make in the states, made from blanks so very good value for money thumbsup
my shopping list includes; +1mm valves, GM racing spring kit, ARP head studs, stage 3 comp cams and vernier sprockets :wacko:
#63 MaDFreeBiRD
MaDFreeBiRD
    VX gone :( 350Z replacement :D
  • 3,385 posts
Posted 08 September 2008 - 03:53 PM
Vocky where abouts in the country are you? i HAVE to see your car when it is all done! from all the pics i have seen it looks immaculate and you know your stuff about these engines! I really do wish you luck with this project chinky chinky
#64 vocky
Posted 08 September 2008 - 04:00 PM
it was immaculate last year, but since the total vauxhall feature I've been driving it not cleaning it, exactly what it was made to do rallly but I suppose it would still be classed as 'clean' B)
#65 Muncher
Muncher
  • 4,494 posts
Posted 08 September 2008 - 04:05 PM
Let me know if you order some bits as we could put it down for one shipment to save postage. What would the valves give me? I don't need the cams. Would pistons give me anything worthwhile in a supercharged engine? I guess the head studs you need to replace when you swap the head and can't be re-used? Sorry, lots of questions but you're the man with all the answers :P
#66 Jameshs
Jameshs
  • 3,511 posts
Posted 08 September 2008 - 04:14 PM
I am tempted by a few bits now then
#67 vocky
Posted 08 September 2008 - 08:30 PM
not sure when I will order the parts, I have quite a few other bits to sort out first
the wasted stem valves will give much better flow than the standard valves and the pistons are stronger than the standard ones
the weakest parts of the z22se are; the old type timing chain, then the rods, next is the pistons and finally the cylinder head :rolleyes:
#68 Muncher
Muncher
  • 4,494 posts
Posted 08 September 2008 - 08:36 PM
At what kind of power levels do the pistons fail?
#69 slindborg
Posted 08 September 2008 - 08:37 PM
An LSJ/Saab one ?
I'm not posting it to sodding France :P
#70 slindborg
Posted 08 September 2008 - 08:38 PM
chap, you really need to read the GM sport compact tuning PDF for the L61/Z22SE (easily googleable). It covers all this kinda info well :D
#71 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 08 September 2008 - 08:39 PM
How much is import duty - is it a percentage of value, or a one off charge (or is it effectively just VAT in disguise) :unsure:
#72 slindborg
Posted 08 September 2008 - 08:41 PM
can vary from nothing to 100% of the value iirc.... plus then add in the shipping companies handling fee (read up on royal fails latest con).
It certainly seems the easy holiday of getting stuff from the US without duty costs is over :( it used to be 90% sure of not being charged, now its more like the other way round
#73 Muncher
Muncher
  • 4,494 posts
Posted 08 September 2008 - 08:47 PM
I've got it, but am just busy at the moment :P I'll read it at lunch at work tomorrow.
#74 Winstar
Winstar
  • 4,264 posts
Posted 08 September 2008 - 10:02 PM
if you go to the back of the 3rd edition theres a failure matrix of what needs replacing at what power or what rpm
#75 Muncher
Muncher
  • 4,494 posts
Posted 08 September 2008 - 10:08 PM
My copy doesn't say what edition it is, it's in black and white but I have a funny feeling that I had one in colour before.... Do you have a link to the 3rd edition?
#76 mandarinvx
mandarinvx
  • 12,621 posts
Posted 08 September 2008 - 10:22 PM
The 3rd edition is here - toward the bottom of the page thumbsup
#77 Jameshs
Jameshs
  • 3,511 posts
Posted 08 September 2008 - 10:53 PM
Vocky when would the stage 2 cams be needed or should i just get the stage 1's. I am aiming for TB's with some flow work but dont really want to touch the bottom end unless i have to. Whats the old type chain? I have a 2002 so i guess it will have it??
#78 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 09 September 2008 - 08:19 AM
Vocky Where's the best place to get your spares for the dremel , i.e the sanding rolls ?
#79 vocky
Posted 09 September 2008 - 08:27 AM
Vocky
if you are lazy like me then B&Q stock loads, I buy the Dremel 'tin' which costs £10 as there's loads of bits inside thumbsup
#80 Baron Von Scubadaddy
  • 6,645 posts
Posted 09 September 2008 - 08:29 AM
these any good
clicky
