to get that sort of power you will need;I am ideally looking for around the 230bhp mark but dont really want to spend more than £3K? Is that possible.
I think i might go for the stage 2 cams then and while the head is off get it flowed. Dont really want to touch the bottom end though other than removing the balencing shalfs. Does that really make any difference??
webcon throttle bodies kit + stage 5 mapping (stage 1 or stage 3 map supplied with tms kit)
2.5" exhaust system + sports cat + '4-2-1 or 4-1' manifold
+1mm stage 3 head + stage 2 cams
balancer delete + underdrive crank pulley
the beauty of tuning a normally aspirated engine is you can do it in stages rather than spend thousands all at once
I think i will start with the headwork then, will the stage 3 head run on standard managment?
