2.2 + Saab Head
200 replies to this topic
#121 Phil T
Phil T
  • 540 posts
Posted 09 September 2008 - 07:25 PM
What bhp do the tms throttle bodie kit produce?
#122 vocky
Posted 09 September 2008 - 08:14 PM
that all depends on what power your engine has already, but expect about 20-25 bhp increase with a 7000rpm limiter, but with the right parts and a higher rev limit you should see even more gains ;)
what many don't realise is that the webcon throttle bodies change the way the car feels to drive, it's much smoother and sounds fantastic too B)
#123 Winstar
Winstar
  • 4,264 posts
Posted 09 September 2008 - 08:23 PM
the problem with the TB's is that to make the most of them you need alot of work on the engine before fitting them becomes really benificial.
#124 slindborg
Posted 09 September 2008 - 08:29 PM
and to have someone competant to calibrate the ecu (oops i mean map).....
#125 Jameshs
Jameshs
  • 3,511 posts
Posted 11 September 2008 - 08:39 AM
But surley thats achieveable in stages?
#126 vocky
Posted 11 September 2008 - 08:56 AM
of course, you can just add one part at a time, like exhaust backbox, then downpipe, then manifold etc etc
#127 Jameshs
Jameshs
  • 3,511 posts
Posted 11 September 2008 - 11:08 AM
Manifold for me then next, whats that regal manifold like?
#128 slindborg
Posted 11 September 2008 - 12:32 PM
the cast one is heavy (and far far far far far cheaper from Germany).... the tubular one they had on their site is no longer avaialable :(
#129 vocky
Posted 19 September 2008 - 06:57 PM
finally finished the porting :sleepy:
need to get the machining done next :rolleyes:
#130 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 19 September 2008 - 07:22 PM
Looks great mate B)
#131 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 19 September 2008 - 07:47 PM
Stunning chinky chinky
#132 vocky
Posted 30 September 2008 - 10:38 AM
the new cam cover arrived, still waiting for the coil pack cover and the expansion tank metal pipe
#133 rsg
rsg
  • 3,306 posts
Posted 30 September 2008 - 11:39 AM
B) I like. Where did you get the cam cover from Vocky?? And are you going to get the head flow tested once its all done, would like to see the results?
#134 vocky
Posted 30 September 2008 - 12:03 PM
cam cover was £93 brand new from the vauxhall dealer, it's for a vauxhall z20net but has saab written on it :lol: winstar has shown me a way to check the flowrate, when I get the time I will give it a go thumbsup
Edited by vocky, 30 September 2008 - 12:05 PM.
#135 Jameshs
Jameshs
  • 3,511 posts
Posted 30 September 2008 - 12:08 PM
Whats goes on the end thought thats not covered?
#136 slindborg
Posted 30 September 2008 - 02:02 PM
cheese...
come on use a bit of imagination please.
one of them is filled with the camshaft anyway and the other can be filled with a tirmmed down bit of ally/steel (or use a SAAB cam cut down to fill it.)
#137 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 30 September 2008 - 02:53 PM
Here's mine
Edited by speedster, 30 September 2008 - 02:54 PM.
#138 mandarinvx
mandarinvx
  • 12,621 posts
Posted 30 September 2008 - 06:08 PM
:blink:
#139 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 01 October 2008 - 10:39 AM
Oops, thought I had vx220.org setup as a safe link....
You can view the images here
CLICKY
#140 vocky
Posted 02 October 2008 - 11:26 AM
the coilpack cover and water pipe arrived :)
I've done a few mods to get everything to work together, the coilpack had to have the plastic trim and z22se mounting lugs removed, then the cam cover had to have a couple of lugs trimmed back to allow the modified coilpack to sit correctly and the water pipe mounting bracket was trimmed of some excess.
I also trial fitted the water temp sender adaptor, this is an additional sender for my revotec temp gauge as the webcon Alpha ecu uses the original sender position on the thermostst housing.
Edited by vocky, 02 October 2008 - 11:27 AM.
