2.2 + Saab Head
200 replies to this topic
#161 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 18 November 2008 - 03:50 PM
Hmmm, throttle bodies :groupjump:
sorted out the wiring looms, so now they look factory fitted, not a good pic to see them :rolleyes:
vocky where you get the longer trumpets for the t/b and what is the benefits of longer ones thumbsup looking good
#162 siztenboots
Posted 18 November 2008 - 04:04 PM
pneumatic valves , ala Renault F1 ?
can see the water pump there, there was some guy on here "Adam" at the national that had replaced it with a electric one ?
Edited by siztenboots, 18 November 2008 - 04:06 PM.
#163 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 18 November 2008 - 04:38 PM
Imnotworthy Imnotworthy Imnotworthy
#164 VIX
VIX
  • 9,497 posts
Posted 18 November 2008 - 05:03 PM
That is all way, way too shiny!! thumbsup
#165 alanoo
alanoo
  • 1,324 posts
Posted 18 November 2008 - 05:45 PM
Just a quick correction,
the "special" valve driving Renault F1 had a few years ago was magnetic, also reffered as camless as each valve was driven by a magnet
Pneumatic "valves" are in fact pneumatic springs, almost all (if not all) F1 teams are using this as simple springs could not work at 20000 rpm
so this one is not Renault F1 specific ;)
#166 vocky
Posted 18 November 2008 - 07:27 PM
they made little difference to my phase I engine, perhaps a little mid range, but should help my phase II
they are actually 45 dcoe trumpets modified to fit the itb's thumbsup
you mean no valves :lol:
I decided against an electric pump this time, I believe 'Adam' had a problem where to locate the pump but has it sorted now. I have figured out a different method for installing one, so could/should have fitted one :rolleyes:
:lol:
#167 vocky
Posted 30 November 2008 - 10:35 AM
thought I would show the difference between the cam lobe profiles of a saab turbo cam and a comp cams stage 3 :rolleyes:
saab on the left, stage 3 on the right :D
#168 siztenboots
Posted 30 November 2008 - 11:24 AM
I need some trick cams for my zlet , anyone got an old 20xe inlet spare ?
Edited by siztenboots, 30 November 2008 - 11:24 AM.
#169 slindborg
Posted 30 November 2008 - 08:35 PM
whore it up on MIG or vauxsport for an inlet :D
#170 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 30 November 2008 - 11:50 PM
A few more cam pics, just for the sake of it :)
Standard
Comp Cams Stage 1
Side by side (though hard to compare at this angle :rolleyes:)
#171 vocky
Posted 08 December 2008 - 03:45 PM
I have had the valve seats enlarged for the +1mm wasted stem valves and also the head skimmed thumbsup
next job was to fit the new valve seats, modified oil seals, double valve springs and titanium retainers. I checked for coil bind by careful measuring and it all looks good :D
next job is to fit the head and set up the timing
#172 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 08 December 2008 - 04:29 PM
Don't you ever stop :rolleyes: :lol:
#173 vocky
Posted 11 December 2008 - 01:14 PM
next job was to fit the head, set up the GM vernier sprockets. There appears to be a problem with the pressure relief valve sticking on some z22se oil pumps so I fitted a brand new oil pump.
next was the exhaust manifold, I have rewrapped it as the heat was starting to affect the clam :(
new gasket for the webcon throttle bodies
and all back together Imnotworthy
#174 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 11 December 2008 - 01:19 PM
Hi vocky. Great work! Question - How easy is it to get at the oil filter with the iTBs installed?
#175 vocky
Posted 11 December 2008 - 01:22 PM
IMPORTANT
if you fit a LSJ / SAAB / Z20NET head you must not use z22se spark plugs anymore :excl:
the LSJ / SAAB / Z20NET (sandcast) heads use a 'flat seal' spark plug rather than the z22se (lostfoam) heads 'taper seal' spark plug. Also the z22se spark plug sits 5mm further into the combustion chamber and can touch the piston :beat:
luckily for me I cranked the engine over by hand and felt the 'contact', so glad I never tried starting it :borg:
I have fitted some Saab Iridium plugs for now and it started first time :D
#176 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 11 December 2008 - 01:23 PM
very colorful .......just in time for x mass ;)
you'll have to teach me mechanics I'll teach you cooking lol ;)
well done and keep going
#177 vocky
Posted 11 December 2008 - 01:24 PM
no more difficult than with a standard inlet, perhaps a little easier :unsure:
#178 vocky
Posted 11 December 2008 - 01:30 PM
stick to the cooking it's more enjoyable than mechanics, especially at this time of year :D
#179 techieboy
Posted 11 December 2008 - 01:42 PM
Phew! Close call there. Thank God you did turn it over by hand and are sensitive enough to have felt the contact. I'm pretty sure I'd have just happily fired it up. :blink:
Great news that it's up and running. When are you back to Northampton to get the map sorted?
#180 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 11 December 2008 - 01:51 PM
I'm considering a remote oil filter set-up for my build
CLICKY
