Courtenay Harrup Supercharged A Stage To Far!
174 replies to this topic
#81 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 01 February 2009 - 08:25 PM
Jon did you get my email?
Hi Nick I've had the weekend off, I'm back in tomorrow I will have a look then. Cheers
cheers chinky chinky
#82 Baron Von Scubadaddy
  • 6,645 posts
Posted 01 February 2009 - 09:36 PM
Wish I hadn't read this now. I want a super charger ! and I want it bloody now !!!!!
#83 Nev
Posted 02 February 2009 - 07:47 PM
God almighty, that power curve is utopia! I've never seen a BHP curve to linear - and I'm sure you haven't either ;)
#84 Jon
Jon
  • 183 posts
Posted 02 February 2009 - 09:14 PM
Our Old stage 2 S/C used to climb in a straight 45 degree to the limiter before we raised the rev limit to past 6300 only then did we see the curve radius and drop. We had allot of customers fit shift lights as it was very easy to hit the limiter as there was no tail off in power! With Nicks we just did not have the bottle to run the engine any further than 7000 as the fuel pressure had started to drop and the lamda was climbing :wacko: The cams have now been changed to a softer profile (with a much nicer tickover) once we have run it agin we will post a fresh graph, we may even see the power graph peak this time! :lol:
Edited by Jon, 02 February 2009 - 09:16 PM.
#85 slindborg
Posted 02 February 2009 - 09:22 PM
Jon, also worth considering is the Saab T7 ECU with tronic T7 suite ;) ready for boost and ETB control etc... just need to get your head round working in the torque manager domain rather than simply fuelling as per normal in most aftermarket ECU's
#86 Exmantaa
Posted 02 February 2009 - 10:10 PM
Then you can also think about fitting the P12 ECU from the original supercharged LSJ engine onto the 2,2. Should be almost Plug & Play, and together with the HP-tuners program it is pretty much full programmable. (Immobiliser can be switched off, etc.) Only point is that it uses a different crank sensor pattern, but that can be easily solved with an external trigger wheel. (Hmmm... Why didn't I think of that before, as I have a P12 ECU lying around, inluding wiring loom and all the LSJ sensors. I even have a complete engine. :rolleyes: )
#87 rik
rik
  • 2,187 posts
Posted 02 February 2009 - 10:12 PM
does the coil pack use the same sensing technology?
#88 PaulCP
PaulCP
  • 6,066 posts
Posted 03 February 2009 - 08:38 AM
Jon, Sue has banned me from phoning you & is monitoring the dialled numbers on our phones but i'll give you a call as soon as i find a public box that works. :rolleyes:
#89 alanoo
alanoo
  • 1,324 posts
Posted 03 February 2009 - 09:23 AM
Hum, not sure a Trionic 7 will work when receiving nothing from the CAN bus and the PBus
(+ the Saab derivates of the LSJ use a Trionic 8)
Edited by alanoo, 03 February 2009 - 09:26 AM.
#90 slindborg
Posted 03 February 2009 - 10:23 AM
was only lobbing other ideas up :D
not sure if you can turn can and Pbus off with T7suite or not... only had a brief look at it last night.
#91 Exmantaa
Posted 03 February 2009 - 10:28 AM
That's why I prefer the GM P12 Ecu. No CAN worries... :rolleyes: But the P12 LSJ uses a coil-on-plug system, with an extra cam timing sensor in the LSJ head... That complicates things, so not an easy swap.
#92 Jon
Jon
  • 183 posts
Posted 03 February 2009 - 09:06 PM
OMG why didnt I think of that :rolleyes: which must be the same as the Z20NET Vectra ECU !?? which Stephan has mapped. I will ask him if he has a full damo;s file for it. I will also have to check out how cambus dependent it is, in other words if to get it to run how many other control units we will need.
Thanks Stuart thumbsup
#93 Jon
Jon
  • 183 posts
Posted 03 February 2009 - 09:18 PM
I think I'm also going to check this route out as well. With the crank trigger pattern this is not a problem as I also have an LSJ which I was going to use in my VX with an external trigger wheel to work with the 2-2's Delphi ECU. So for 2-2 we just need to mount a 60-2 trigger to work with the P12 ECU. Humm also know a man who work on this engine during development. though I suspect his bas e cals were on a slave ECU not the P12.. worth an ask
All this help cheers guys, thumbsup
#94 slindborg
Posted 03 February 2009 - 09:24 PM
TUT TUT you were doing SO well till that annoying balls up lol
(ignoring the typo) its NOT CANBUS!!!!!!!!!!!!!!!!!!!!!!!!!! ARGHHHHHH
its CAN plan and simple. Anywhere it says CANBUS on the tinterwebs is a completely incorrect load of sh*t!
#95 Exmantaa
Posted 03 February 2009 - 09:57 PM
Not sure if the European z20net uses the same ecu as the US LNF engine, but that one is also supported by HP-tuners. And there is tons of good info on their site & forum on specific engine tunes (http://www.hptuners.com/forum/) or the other US Ecotec forums. Their credit system is a bit strange, but for you as "dealer" an unlimited license for a particular engine/ecu type is probably a good option. Keep us informed. thumbsup
#96 Jon
Jon
  • 183 posts
Posted 03 February 2009 - 10:14 PM
Cambus :drink: sometimes my typo's crack me up! most of the time I just wish I paid more attention in English :beat: :lol: makes mental note ..use word"canbus" more when posting :poke: :lol:
#97 slindborg
Posted 04 February 2009 - 08:41 AM
canbus is pretty much my number 1 pet hate.....2nded by you lot :P lol
#98 Jon
Jon
  • 183 posts
Posted 04 February 2009 - 09:05 AM
Love you too :wub: LOL
#99 slindborg
Posted 04 February 2009 - 09:08 AM
I know, its hard not to love me really :groupjump:
#100 Sicey
Sicey
  • 3,761 posts
Posted 05 February 2009 - 09:55 PM
I am so glad I haven't had mine done yet Imnotworthy This sounds like great news, I hope the prices are competetive against the old conversion thumbsup Good work guys Imnotworthy
