Suspension Question / Problem
#21
Posted 25 February 2009 - 02:56 PM
#22
Posted 25 February 2009 - 02:58 PM
#23
Posted 25 February 2009 - 03:20 PM
#24
Posted 25 February 2009 - 03:29 PM
Shout at Gaz, and ask them to pay you new wishbones
Did you ask for new wishbones from Nitron then??
#25
Posted 25 February 2009 - 04:24 PM
im going to do that right now
#26
Posted 25 February 2009 - 05:05 PM
It's a bit more complicated, mine occured when hitting a security rail on a track so was a lot more than any "normal" event could be.
But I asked Nitron if they were aware of any bump stops issues yep...
#27
Posted 25 February 2009 - 05:11 PM
#28
Posted 25 February 2009 - 06:19 PM
#29
Posted 25 February 2009 - 06:28 PM
#30
Posted 26 February 2009 - 02:13 PM
#31
Posted 26 February 2009 - 06:53 PM
Edited by severnless, 26 February 2009 - 06:55 PM.
#32
Posted 27 February 2009 - 05:17 PM
firstly i would like to comment that gaz's c/s is very good and i was very pleased with whats been arranged.
the springs warren sent me out arrived this afternoon, so when i got home i whipped off the wheel and had propper look at the wishbones.. and not only is it dinted but looks bent.
these are the springs i received and they are actaully 475 not 425 like i put earlier. lol
then i took the wheel off and had a look, i wondered how far the wheel would have to travel inside the arch to get the top wishbone to make contact with the subframe, so i removed the coilover and jacked it up.
as you can see its pretty far inside the arch, so first thing i did was measure the gap between the two bolt holes to get a distance
and then measured the coilover.
the gap that the coilover was to fit in was just roughly 13.5" and if we measure the coilover its 17.5" ish from centre hole to centre hole.. but without a spring its 14" (inc bumpstop) so the coilover effectivly does nothing to stop the wishbone hitting the tub, so as a conclusion i didnt think that the bumpstop was big enough..
i spoke to warren to explain my findings and at the time nothing was mentioned about replacing the wishbones but he agreed so very kindly to send me out some new rear shocks so i could fit the new springs and use them.
and also fit 2" bumpstops, hopefully it should suffice in stopping this problem
i also suggested that he may want to look into using the 2" for all the rear sets he sends out for the vx220
** please note.. this has not happened because of the gaz kit, if you have any aftermarket coilover on regardless of make i would suggest you whip your wheel off and check it out**
** make sure of the following
- ride height isnt stupidly low
- ride stiffness isnt very soft
- make sure you dont hit any bug potholes (this is what happened to me)
#33
Posted 27 February 2009 - 06:42 PM
I'm not sure how you come to this conclusion surly a produce should be tested to make sure the bump stop is big enough to stop the wishbones being damaged?
#34
Posted 27 February 2009 - 06:55 PM
Surely if it was caused by the bump stops not being big enough how can it not be GAZs fault?
#35
Posted 27 February 2009 - 09:57 PM
I'm sorry Chris, but although i have used 'Gaz' kit before on my kit cars, i have been very impressed with it, unfortunately they have supplied it to the VX220 market without enough research, your wishbones have proved this!
so i'm sorry but they are 'not fit for purpose'
Unless they sort you out with some new wishbones and supply every other VX220 owner who has purchased their shocks with the upgraded bump-stops then i don't think i will be a customer of theirs.
Good luck fella
#36
Posted 27 February 2009 - 10:18 PM
what i meant was they worked as supplied.. and the only reason it happened is that i hit a big assed pothole, under normal circumstances (well saying that we live in britain and our roads are sh**) but what i mean is they work the same now as they did when i got them, so they didnt fail or anything like that,,
i would say that if you are worried about it then by all means call warren up and get them to change the bumpstops.
#37
Posted 28 February 2009 - 05:12 PM
The shocks may not have failed but their design allowed the wishbones to hit the tub. Which is now going to cost you £400+ to fix...
If the bump stops where of an adequate size then this wouldn't have happened?
Edited by goodeg, 28 February 2009 - 05:14 PM.
#38
Posted 28 February 2009 - 07:57 PM
ok i would just like to follow on now it has been sorted out.
#39
Posted 28 February 2009 - 08:17 PM
#40
Posted 28 February 2009 - 09:07 PM
