Jules, i would tend to agree with you, but if you think of how many people have the same shocks, why is it that there are no other problems with other peoples setups?
Most likely nobody else has found the problem you have, there may well be other people in the same situation.
two possibilities that i can think of are running too low or possibly the dampers set too soft
I dont think thats our problem either, a combination of bad spring ratings and bump design is the suspension/damper design fault...not the people who buy them.
so because i know that i wasnt running too low, and that the dampers were infact set quite hard i have to rule this out, so i have to investigate other means, it must be something thats happened to my car that is out of the ordinary, and the only thing to spring to mind is a pothole i hit a couple weeks back.
For clarity (not taking the p*ss here) I think you need to define 'too low' I got my Gaz via Joes group buy and set the ride height standard (no pre tension or lowering) and Ive felt mine bottom out whilst set with relatively 'hard' rebound.
i think the pothole i hit was on this video, just after overtaking the van... so i was accelerating down a hill and just as i get to the bottom i hit the pothole, whether its has something to do with the force of the sudden uphil (forcing the car down) and hitting the pothole at the same time i dont know..
I cant see a situation where hitting a single pothole will damage OS & NS wishbones at the same time, the car would have to be either airbourne or compressed equally to do that.
For Gaz to offer you a couple of higher load springs is a compromise IMO, you need new wishbones (if you can prove it) and this thread alone is going to see lots of people questioning whether the Gaz option is worthwhile.
