High-spec Na 2.2 Screamer
83 replies to this topic
#21 vocky
Posted 07 June 2009 - 03:02 PM
thats the shizzle adam!
now the question is can i hook that up to my m62? :lol:
(i can picture vocky shaking his head :lol: )
you would need to remove the m62 and fit a 2.4 inlet manifold for the rotrex :rolleyes:
#22 The Batman
Posted 07 June 2009 - 03:05 PM
can i not modify the inlet manifold for a hole in the bottom for twin superchargers?! :lol:
#23 vocky
Posted 07 June 2009 - 03:09 PM
twin sc's :rolleyes:
#24 The Batman
Posted 07 June 2009 - 03:10 PM
:lol:
#25 southpaw
southpaw
    sans vx for now
  • 2,462 posts
Posted 07 June 2009 - 03:36 PM
ot but what is the advantage of the rotrex £s/weight/bhp?
#26 The Batman
Posted 07 June 2009 - 03:38 PM
you will have to wait until the guinea pig is finished ;)
#27 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 07 June 2009 - 03:44 PM
I think the charger itself is more expensive, but money is saved on other aspects, overall may be cheaper :unsure:
The 30 only weighs 5kg, if that's the one to be used, with no seperate cast manifold
No idea what BHP - the C30-74 is capable of 150-300bhp; the C30-84 is 200-320bhp; and the C30-94 is 250-400bhp. Tho the C30 is their off-the-shelf design, it may be possible to spec a custom one
#28 The Batman
Posted 07 June 2009 - 03:46 PM
does anyone want a c30-94? ;)
#29 Muncher
Muncher
  • 4,494 posts
Posted 07 June 2009 - 04:16 PM
Be patient and wait for the manifold to come in, it's worth the wait.
#30 fiveoclock
fiveoclock
  • 9,453 posts
Posted 07 June 2009 - 04:27 PM
Thanks, thats exactly what I'll do, just hope its not too long.
#31 Winstar
Winstar
  • 4,264 posts
Posted 07 June 2009 - 04:30 PM
rotrex are centrfugal compressors* which means they are far more efficient than even a harrop so less parasitic loss and less cooling required. However they would only mak sense if you where either going make a cheap sc conversion that made 250 - 260 bhp without charge cooling or make a 400bhp monster using a C30-94 which has one of the best compressor designs available.
*they are actually Holset, my old company, compressor stages mated up with rotrex's epicyclic gearing.
#32 Retset
Retset
  • 1,766 posts
Posted 07 June 2009 - 05:25 PM
I reckon a Rotrex aiming for 240bhp using just a side pod mounted intercooler should be just about perfect ;)
#33 The Batman
Posted 07 June 2009 - 05:28 PM
i thought the reason why courtenays scrapped the idea of side mounting a intercooler in the side pod was because it wasnt cooling it enough? i think a couple of vx's had this setup :unsure: but was then scrapped for the charge cooler up front
#34 MMSB
MMSB
  • 178 posts
Posted 07 June 2009 - 07:48 PM
Can I ask why you would say that?
250-260 bhp would be more than enough for me, but I would think that with no chargecooler/intercooler you would only have that bhp for a short while, so no good for track driving, especially with high temperatures... Am I wrong?
#35 mandarinvx
mandarinvx
  • 12,621 posts
Posted 07 June 2009 - 07:53 PM
You may only need an oil cooler on a Rotrex setup, which could be side pod mounted
The Rotrex doesn't generate anywhere near as much heat as the GM / Harrop, so induction temps will be much lower anyhoo :)
#36 slindborg
Posted 07 June 2009 - 07:54 PM
I'd take Winstars advice rather well on that front ;)
since the rotrex isnt a complete heat generator like the hEaton then charge temps arent such an issue so you dont need to cool that and can swing it with decent fuelling and timing.
#37 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 07 June 2009 - 08:00 PM
I hear there is already such an engine in a vx220 Imnotworthy
apparently it has a 7900rpm limiter on a high compression engine with webcon throttle bodies, running between 220 and 240 bhp depending which rolling road you believe ;)
Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy
7900PRM! :tt:
#38 MMSB
MMSB
  • 178 posts
Posted 07 June 2009 - 08:04 PM
Oh, I didn't mean too look like I was doubting his advise, I realise from his posts that he knows very well what he talks about!
My question was just because I am looking to get some more ou of my engine but want to track it, so a cheaper S/C setup would be perfect for me if it did "take the heat"
Courtenays themselves aknowledge that their Stage 1 conversion would not resist track use, hence my question...
#39 slindborg
Posted 07 June 2009 - 08:10 PM
no where that I know of has a rotrexed VX on the road as yet. I'm sure there are a few in the pipeline though as its pretty much a DUHHHHHHHHH option over the hEaton. So it wont be a simple drive in drive out option at the "tuners" yet.
#40 Muncher
Muncher
  • 4,494 posts
Posted 07 June 2009 - 08:28 PM
How would the boost and torque graphs differ between an M62/Harrop and a Rotrex? I was led to believe the power delivery/driveablity characteristics were not as good on a Rotrex charger.
