all fitted, works really well!
go a go pro for xmas so afew wide angle garage shots
not much room to work i can tell you that much!
exhaust and turbo back on
playing with carbon
mounted a section above the wheel as i want a couple of buttons on the wheel for launch control and overboost setting on the EBC allowing a higher boost level for a certain amount of time meaning i can potter around with 250bhp but if i want 350 just press that
made a surround for the column too as its smaller looks neater
also i fitted a clutch switch along with the brake switch so i can use the full throttle gearchange function in the omex
Edited by Thealastair34, 01 January 2013 - 07:46 PM.
