Project Snow White
448 replies to this topic
#121 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 17 May 2013 - 03:31 PM
Got opcom here. Ecu is from onyx but key is from snow white. Do we need to phone vauxhall for the 4 digit code from onyx?
#122 vocky
Posted 17 May 2013 - 03:45 PM
and the transponder around the steering lock is from ......... ?
#123 vocky
Posted 17 May 2013 - 03:46 PM
you will need the four digit code for the ecu, so from the black car.
then you need to match the transponder and key chips to the ecu.
#124 J4EY D
J4EY D
  • 3,236 posts
Doh!! :beat:
#125 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 17 May 2013 - 03:47 PM
Every thing including Steering wheel and lock is from Snow white. Ecu is from onyx. Will getting the key from onyx help?
#126 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 17 May 2013 - 03:48 PM
Doh!! :beat:
On 17/05/13 at 16:44pm I DIDN'T GET SOMETHING RIGHT!!!
#127 vocky
Posted 17 May 2013 - 03:50 PM
If you can get the black cars keys you will also need the transponder from around the steering lock of the black car.
Plus you must remove the key chips from the white cars keys and then fit the black cars key chips into the white cars keys, otherwise the ecu will throw a wobbly with two different key chips present.
#128 vocky
Posted 17 May 2013 - 03:53 PM
it really is easy, you just need the black cars matching 'ecu / transponder / key chips' and remove the original white cars key chips.
Edited by vocky, 17 May 2013 - 03:53 PM.
#129 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 17 May 2013 - 03:54 PM
Doh. Not sure we can get the transponder back as onyx is locked in a yard... Looks like we need the code.
#130 vocky
Posted 17 May 2013 - 03:56 PM
if you get the black cars ecu code then simply programme the original transponder and key chips on the white car to the black cars ecu
#131 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 17 May 2013 - 04:04 PM
Think that's what we need to do but vauxhall can't get it till Monday now. We have an angry Stuwy now :-(
#132 techieboy
Posted 17 May 2013 - 04:28 PM
I'm not sure just having the original code will solve it either. I have a feeling the ignition lock transponder might need to be blank (never programmed) to pair it up with the keys and ecu.
#133 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 17 May 2013 - 04:33 PM
thumbsdown  Worked my ass off all week to get to a family do this weekend and even with everything.. there is no way I could have anyway!
so what do I need? a new barrel/transponder and the ECU pin? and then new keys (presumably they come with the barrel/transponder)
:beat:  :angry:  arrrgggg
Literally built a car in two days FOR NOTHING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Edited by Stuwy, 17 May 2013 - 04:33 PM.
#134 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 17 May 2013 - 04:44 PM
What's wrong with snow white's ECU?  Sounds like installing that instead of the onyx ECU means everything would match
#135 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 17 May 2013 - 04:48 PM
It would have NA map.
#136 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 17 May 2013 - 04:57 PM
Stewy had a stage2 SC map on his old ecu. So to save money and not have to get it all mapped again he's logically using the same ECU. I assume now the cars in the insurers compound ready to be sold on as a cat car. No chance of getting it back. :(
#137 Lizy
Lizy
  • 703 posts
  • Interests:Singing, Music, Modeling, Cars, Going out, Stuff..
Posted 17 May 2013 - 04:59 PM
Snow Whites ecu hasn't been mapped for the sc so it wouldn't work...
#138 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 17 May 2013 - 05:04 PM
Ohh, I wasn't aware that onyx had been supercharged. What a bugger :(
#139 vocky
Posted 17 May 2013 - 06:23 PM
so what do I need?
:yeahthat:
#140 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 17 May 2013 - 08:39 PM
Cool thanks vocky.
