Volvo T5 Engine Transplant
#221
Posted 18 November 2015 - 11:22 AM
#222
Posted 19 November 2015 - 08:06 AM
its sch10 pipe nev. 2.8mmWhat thickness walls are those 90 degree sanitary bends BTW ? Awesome update as usual
#223
Posted 19 November 2015 - 08:37 AM
#224
Posted 20 November 2015 - 05:23 PM
Ahh, excellent, nice and thick to cope with the heat
#225
Posted 20 November 2015 - 05:38 PM
#226
Posted 27 November 2015 - 11:35 PM
#227
Posted 27 November 2015 - 11:36 PM
#228
Posted 28 November 2015 - 03:34 PM
#229
Posted 28 November 2015 - 04:27 PM
Havent done enough for an update yet but will be soon
hopefully with the exhaust finished.....
Worthy of a project thread of its own ::
#230
Posted 07 December 2015 - 04:20 AM
Decided not to use the pie cut 90° bends we made out of the 3" pipe as it looked a bit agricultural and bought some mandrel 90s instead.
Started by attaching the turbo downpipe flange to a 90 bend .
From there we routed all the pipe in the best way we could including the flex and cat and taped in position. Leaving as much clearance as possible between the exhaust and driveshaft and rear engine mount.
At this point we realised ill have to loose a small section of the rear clam on the underside just to facilitate the cat section as it needs to sit low for the silencers to fit above it.
Once we got the position for the main run of pipe we tacked it all up.
Next we turned our attention to the silencers. Lots of cutting, grinding and welding again to make the bends which attach the silencers to the main pipe.
After notching the ends of the tubes to fit up against the 3" pipe couldnt help but have a preview of what it was going to come out like. This is as far as we have got at the moment. Its slow progress
And lastly a preview of what the new tailpipes are going to look like in the rear clam .
Edited by vxt5, 07 December 2015 - 04:28 AM.
#231
Posted 07 December 2015 - 06:25 AM
Looks amazing as usual. One thing I'd mention is will that back box be enough to get sound levels down? I only mention it, as I have terrible noise problems on my car and the next exhaust I make will have to be tested/modified/re-tested in a semi fabricated form to ensure I can get the DB level down.
Edited by Nev, 07 December 2015 - 06:39 AM.
#232
Posted 07 December 2015 - 07:13 AM
#233
Posted 07 December 2015 - 08:59 AM
Surprised you're not putting a second box on the left hand side.
#234
Posted 07 December 2015 - 02:22 PM
#235
Posted 07 December 2015 - 06:40 PM
A hansen racecar team here got some heat/sound blanket developed. http://www.econtras....-sportauto.html
Probably silly expensive, but once you have investigated all others.
#236
Posted 07 December 2015 - 09:37 PM
There will be another box on the otherside also Nev but i cant tell you what the outcome will be as for the noise. im hoping this will be sufficient enough but i wont really know until the cars up and running. If i find it is too loud wel'll tackle that problem as we encounter it.Looks amazing as usual. One thing I'd mention is will that back box be enough to get sound levels down? I only mention it, as I have terrible noise problems on my car and the next exhaust I make will have to be tested/modified/re-tested in a semi fabricated form to ensure I can get the DB level down.
#237
Posted 08 December 2015 - 07:16 AM
#238
Posted 08 December 2015 - 03:06 PM
what type/brand (absorption/reflexion?) of mufflerboxes are you using?
#239
Posted 11 December 2015 - 02:22 PM
Had a quick look for them but couldn't find them... Any chance you could get a link for me? What diameter are they?Ther will be a second box on the other side just havent got that far yet. Good old flea bay for the covers mopey.
#240
Posted 11 December 2015 - 06:31 PM
i bought them as tips but will be dismantling to use for mine as theyre only riveted on... http://pages.ebay.co...3899600&alt=web RossHad a quick look for them but couldn't find them... Any chance you could get a link for me? What diameter are they?Ther will be a second box on the other side just havent got that far yet. Good old flea bay for the covers mopey.
