Possible First Vx 2.4 Harrop 1900 Build
388 replies to this topic
#221 Exmantaa
Posted 09 August 2016 - 02:40 PM
Just thought I would share how much further a head this 2.4 is compared to mine 2.2
Cobra = 2.4 stage 3 cams 2.7 pulley
Chill = 2.2 stage 2 zzp cams 3.1 pulley
Ignition levels are currently quite even ( minor differences ) but wonder how much of this is down to water meth
Wondering again; why is Chills power dropping of a cliff after 7.2K, while the other keeps climbing till 7.8?  The Harrop SC and the standard intake manifold clearly are not causing an obstruction, and with comparable ignition numbers and no detected knock... ???  :ffs:
#222 1cobrav8
1cobrav8
    Joe is faster than me
  • 516 posts
Posted 09 August 2016 - 02:56 PM
Is it possibly a software issue that was fixed in a later version? Remember i only got my ecu converted April time this year I believe.....
#223 CHILL Gone DUTCH
Posted 09 August 2016 - 02:57 PM
cobra has a dip at 7000-7200 also just to confuse things  :ninja:
#224 siztenboots
Posted 09 August 2016 - 02:58 PM
positive crank ventilation same for both?
#225 Exmantaa
Posted 09 August 2016 - 03:07 PM
I had some play yesterday with Dominique's 2.0 M62. (Wideband learning was not working as it should...)
But his measured powercurve was climbing  or steady till the 7.4-7.5K limiter. No dip around 7K...  :wacko:
Edited by Exmantaa, 09 August 2016 - 03:07 PM.
#226 smiley
Posted 09 August 2016 - 03:09 PM
So, we all need more power to push through the dip... :huh:
Silly pullies for everyone :tt:  (and wi to get the heat back under control........ :happy: )
Edited by smiley, 09 August 2016 - 03:10 PM.
#227 smiley
Posted 09 August 2016 - 03:12 PM
In 3rd gear right?. Which 1cobrav8 is also doing. (and Chill)
#228 CHILL Gone DUTCH
Posted 09 August 2016 - 03:19 PM
That particular run may of been done in second of mine i dont have a note of what it was
cobra is using 3rd no surprise there
#229 CHILL Gone DUTCH
water injection will be coming very soon after zandvoort trip for me
probably with a bigger pulley to
Edited by CHILL Gone DUTCH, 09 August 2016 - 03:25 PM.
#230 1cobrav8
1cobrav8
  • 516 posts
Posted 09 August 2016 - 03:48 PM
Just ordered a 2.6 pulley.....lets see if we can either 1).....break the engine or 2).....Break 500BHP!!!! Place your bets  :huh:
#231 CHILL Gone DUTCH
Posted 09 August 2016 - 03:55 PM
no cobra to atmoshere
me in to inlet
#232 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 09 August 2016 - 04:34 PM
Lunatic! (3th time i type this!) This is over the top in Supercharged form! :-) Curious for the tranny if it can hold . To much agressive i think...
#233 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 09 August 2016 - 04:35 PM
470bhp not enough for you? :lol:
#234 Exmantaa
Posted 09 August 2016 - 04:38 PM
No; 2nd gear runs slamming into the limiter. :wacko:
#235 smiley
iirc the 2.6 on M62 required trimming the snout.
Not sure if the same for the harrop.
#236 Exmantaa
Posted 09 August 2016 - 04:39 PM
I must have a 2.5 Harrop pulley somewhere.. :rolleyes:
#237 vocky
Posted 09 August 2016 - 07:13 PM
Anyone got a Saab engine sitting around I can have might ask Vocky to see if he could build me one 🙂 Stage 3 cams pretty wild
Get your self a Gen 3 block nick Vocky has one
I do have a GEN 3 A20NFT engine available, only done 20k :D
#238 Exmantaa
Posted 09 August 2016 - 08:53 PM
So that will be a reinforced 86mm bore block then with the cast in liners. For sure you're not going to destroy that with some Darton sleeves?
(I have a Gen 3 LE5 bottom block; 88mm bore; <8K. B) )
#239 BadCop
BadCop
  • 96 posts
Posted 10 August 2016 - 02:19 AM
Putting sleeves in an A20NFT makes no sense at all. Less stabilty, thermal conductivity is lower and the surface is softer than the plasmacoated Silicium. The problem with every highpower sc is the parasitic drag. A 500 bhp Turbo engine has about 40 bhp parasitic loss. A 500 bhp sc engine has over 150 bhp parasitic loss. Which results in over 650 bhp mechanical load to take for bearings, rods, crankshaft etc. Also the thermal load is much higher. The question is - as always - how long will it work or how long does it need to work. 1 Powerrun for a big dyno figure? Probably. 402 meters for a 8 or 9 sec pass? Perhaps yes. One fast lap on a racetrack? Could already be the end of it... Half an hour WOT on the track? No. A trackday weekend? Never ever.
#240 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 10 August 2016 - 05:58 AM
:-) I wonder
Edited by NickB787, 10 August 2016 - 06:00 AM.
