2.4 Litre 1900 Harrop Build
428 replies to this topic
#101 Nev
Posted 15 January 2017 - 06:36 PM
As Im sure its going to be used on track, its going to be a monster of a VX220  :tt:
You will need to re-learn everything!  :excl:
I think it will monster almost all road legal cars TBH, what can you think of (under £100,000) that could realistically get past it?
The key will be traction, ie rubber, I guess it would need at least 1100mm of rubber to exploit the power, maybe more to be safer.
It will also be interesting to see how the running gear/bushes/joints cope. This has been one of my main fears when driving mine.
Edited by Nev, 15 January 2017 - 06:42 PM.
#102 Bargi
Bargi
  • 4,483 posts
Posted 15 January 2017 - 06:39 PM
You already got a locking diff?
#103 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 15 January 2017 - 06:49 PM
Yes got a [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]quaife diff fitted [/color]
#104 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 15 January 2017 - 06:52 PM
what size rears are you on  Nev? I'm on 255 zzr
Edited by leevx2.2, 15 January 2017 - 06:52 PM.
#105 CHILL Gone DUTCH
Posted 15 January 2017 - 07:49 PM
Time attack ??
#106 Nev
Posted 15 January 2017 - 11:02 PM
I have 245 fronts and 285 rears. When warm, with Federal 595 RSR tyres and 345 ft/lb they generally don't spin up in 3rd gear so long as the tarmac is good and flat, but it is worry some, cos a little bit of camber change or white lines or grit etc can change that in a split second.
To feel really safe in 3rd gear I think I'd need at least 305 on the rears. With your sort of output maybe more again. Seriously.
I went out with a friend in the (very slight) damp about 3 months ago and was booting it for 70 miles without any drama, then all of a sudden it unexpectedly span up on smooth tarmac at about 90 leptons. Thankfully it stayed straight, but this lottery is constantly there unless you have lots of rubber or TC.
My honest input would be to stay at about 235 on the fronts (so it doesn't get too darty/jiggly) and get as much rear tyre width as you possibly can. It will make the car very camber sensitive though :(
If I had my time again, I'd have probably made my bodywork even wider and put 305 rear tyres on, though this might cause serious chassis rubbing and/or a large offset between the centre line of the wheel and the hub (which has some implications I expect). Too late for me now unless I want to do yet more major bodywork.
Edited by Nev, 15 January 2017 - 11:27 PM.
#107 Exmantaa
Posted 16 January 2017 - 08:04 AM
Well that was an expensive january ordered everything for the build should be with me buy early february
ordered
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]ZZP Girdled Gen3 Block 2.4 l[/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]Ecotec 4340 Connecting rods[/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]Forged & Coated Pistons for LSJ/LE5 88mm 2.4l[/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]oil pump[/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]water pump[/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]all new chain kits [/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]arp head bolts[/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]comp cams 113400 camshafts[/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]Cometic 89mm .040 inch head gasket[/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]Need to order [/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]new injectors [/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]new fly wheel [/color]
[color=rgb(51,51,51);font-family:'Gotham A', 'Gotham B', 'HelveticaNeue-Regular', 'Helvetica Neue Regular', 'Helvetica Neue', Helvetica, Arial, 'Hiragino Kaku Gothic ProN', Meiryo, 'MS PGothic', Roboto, sans-serif;font-size:1em;]new paddle clutch [/color]
Lee, was it not easier/cheaper to just order a complete ZZP Racing assembled LE5 short block? Think that includes everything you have listed above, including a new 2.4 crankshaft etc. and fully assembled. :sleep:
But I did not calculate the numbers...
#108 turbo2015
turbo2015
  • 566 posts
Posted 16 January 2017 - 10:40 AM
ordered
Wow this is going to be a mental build...just reading you comment and googled zzp...didnt know you can buy short block configured with bits from the states http://zzperformance...rt-block-1.html interesting.
#109 Exmantaa
Posted 16 January 2017 - 11:12 AM
Yep. Only "issue" is they have a 2.0 / 2.1 version or the 2.4 litre option. They do not have a version with a 2.2 crank.
Lee; are you making an internal 2.2 (OBD) triggerwheel for the 2.4 crank? (That is one reason why a fully assembled ZZP block is not handy to buy, as you need to remove the crank for fitting the internal triggerwheel.) Or simply go external like the B207's.
#110 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 16 January 2017 - 02:06 PM
i was going to buy the racing engine as its good value for money, but would of had to split it to put my internal trigger wheel in so decided to buy it in bits and build up by Vocky .
plus i didn't want to go external trigger wheel
Edited by leevx2.2, 16 January 2017 - 02:09 PM.
#111 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 16 January 2017 - 02:20 PM
Yep. Only "issue" is they have a 2.0 / 2.1 version or the 2.4 litre option. They do not have a version with a 2.2 crank.   Lee; are you making an internal 2.2 (OBD) triggerwheel for the 2.4 crank? (That is one reason why a fully assembled ZZP block is not handy to buy, as you need to remove the crank for fitting the internal triggerwheel.) Or simply go external like the B207's.
i was going to buy the racing engine as its good value for money, but would of had to split it to put my internal trigger wheel in so decided to buy it in bits and build up by Vocky ,and there is a month waiting list for the engine to be built . plus i didn't want to go external trigger wheel
#112 Exmantaa
Posted 16 January 2017 - 06:18 PM
Internal triger makes sence.
Make sure you have the right measurements, as I remember that the 2.4 triggerwheel has a different diameter than the 2.0 B207 version. It's also differently clocked on the crank, so double check that too. :sleep:
#113 CHILL Gone DUTCH
Posted 16 January 2017 - 06:21 PM
I've often wondered if peter could off set the trigger wheel (2.0 or 2.4) signal in the software to match the z22se trigger wheel setup
#114 Exmantaa
Posted 16 January 2017 - 06:28 PM
He probably can, as it is just 1 number somewhere in the code. But doesn't make much sence, as OBD needs the (odd) 6-1 trigger pattern and all other GM engines use the 58-2 pattern...
Edited by Exmantaa, 16 January 2017 - 06:29 PM.
#115 FLD
Posted 16 January 2017 - 06:46 PM
I wonder how loud this will be??! Sent from my iPhone using Tapatalk
#116 smiley
Posted 16 January 2017 - 07:06 PM
Lee is gonna need a new bumper sticker. :happy:
#117 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 16 January 2017 - 07:47 PM
This may be a problem
#118 The Batman
Posted 16 January 2017 - 08:27 PM
get nev to make you a new exhaust
#119 CocoPops
CocoPops
  • 17,182 posts
Posted 16 January 2017 - 08:59 PM
Back to Nevs point on tyres. Is putting 305 wide tyres really the right answer? Doesn't seem right to me, but hey what do I know.
#120 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 16 January 2017 - 09:06 PM
What size tyres did your Airbus have fitted? ;)
