Loudi V8
149 replies to this topic
#41 mafumoto
mafumoto
  • 123 posts
Posted 04 March 2018 - 02:51 PM
Double post
Edited by mafumoto, 04 March 2018 - 02:52 PM.
#42 mafumoto
mafumoto
  • 123 posts
Posted 05 March 2018 - 08:28 AM
With regards to the gearbox I know the engine has all ancillaries Inc ecu so I'll wait till I collect on weekend and see if the tcu is there aswell Not sure if this engine came with the s-tronic or manual but I will find out saturday
#43 Nev
Posted 05 March 2018 - 11:13 AM
It's running around South wales Scaring the shot out of anyone brave enough to be a passenger The only car I know of with a spore drive
Ah, so you're the skilled man behind that project, good to hear it's finished.
#44 Exmantaa
Posted 05 March 2018 - 11:49 AM
While we're talking about longitudinal engines; I remember some mad Fins: http://www.worldtime...s-from-finland/
#45 mafumoto
mafumoto
  • 123 posts
Posted 05 March 2018 - 12:00 PM
Very nice
#46 mafumoto
mafumoto
  • 123 posts
Doublepost
Edited by mafumoto, 05 March 2018 - 12:01 PM.
#47 mafumoto
mafumoto
  • 123 posts
Posted 05 March 2018 - 12:06 PM
Yup will be keeping the same standard (if not higher as it's my car) of detail going into this project
#48 Exmantaa
Posted 05 March 2018 - 12:55 PM
Very nice
My mistake; they used a LMP2 V6 engine in transverse layout.   :huh:
(Well, they started the project with an Exige V6...)
#49 Arno
Arno
  • 1,238 posts
Anyway heres a little render of the projected outcome
Hope it doesn't end up looking like...
(google 'PG Elektrus'... and don't throw up too much :D )
Always hard to make the rear not turn into a massive flat plane.. The BMW V10 version already suffers from this a little:
Hennesey Venom being a particularly nasty example of the proprtions going to hell in a handbasket IMHO..
Still.. Good luck with the project! Sounds like a cool one.
Of course there was already the original 'Esthi' with the V6 twin turbo Audi engine:
Currently resides in the UK..
#50 Rosssco
Rosssco
  • 4,185 posts
Posted 05 March 2018 - 01:28 PM
The major benefit the Audi's have is their very short engine combo's. The FSI V8 comes in at only 464mm. Add one of the newer transaxles with the forward placed diff, and you have a front pulley to shaft centre length of around ~500mm. I've previously checked that length wise. It will fit. Still need to mod the subframe to allow installation..
https://thefactoryfi...49&d=1491262927
The Esthi is a bit of a weird one. I think it ended up weighing like 1,000kg (from an original 750kg). See the pic below for the huge new subframe and poor drive shaft angle on the modified 4wd gearbox..
http://www.sandsmuse...r/series/esthi/
#51 Exmantaa
Posted 05 March 2018 - 01:45 PM
You happen to know the length of the V6?
And for subframe I once thought about the V6 frame which is wider and has a 70mm longer wheelbase than the S2 (and 40mm longer than a VX220...) and use all the V6 suspension parts
Although a rear facing gearbox will need lots of room in the center section. (So maybe just use the pick-up positions and fabricate a tube frame)
#52 mafumoto
mafumoto
  • 123 posts
Posted 05 March 2018 - 02:17 PM
Wow a monster of a subframe extra 200kg just there 500 mm front to driveline good to know Got my mind set on fwd new type box with diff in front either s-tronic or manual at the mo A rear spoiler helps take away the flatness at the back a bit Maybe the stretch will only be around 6-8 inches now don't mind seeing the back of the gearbox on show through diffuser
Edited by mafumoto, 05 March 2018 - 02:18 PM.
#53 Rosssco
Rosssco
  • 4,185 posts
Posted 05 March 2018 - 02:18 PM
These engines are of a modular design (all being 90 degree V) with essentially just cylinders added to get V8 or V10. So, 464mm (V8) - 90mm (cylinder spacing) + additional drive pulley for SC (30mm?) = 405mm ish.. Engine study guides provide some high-level info:
V6 http://www.vaglinks....TFSI_Engine.pdf
V8
http://www.tbfh.org/...-StudyGuide.pdf
#54 mafumoto
mafumoto
  • 123 posts
Posted 05 March 2018 - 02:20 PM
Engine study guide between the cau and rs4 is an interesting read too
#55 Rosssco
Rosssco
  • 4,185 posts
Posted 05 March 2018 - 02:28 PM
Yep, a bit more than just red painted cam covers! :lol:
#56 mafumoto
mafumoto
  • 123 posts
Posted 05 March 2018 - 03:36 PM
Wonder if I can get the r8 inlet to fit
#57 Rosssco
Rosssco
  • 4,185 posts
Posted 05 March 2018 - 04:28 PM
It's pretty tall as the R8 engines uses a form of dry sump allowing the engine to be mounted pretty low.
#58 mafumoto
mafumoto
  • 123 posts
Posted 05 March 2018 - 05:26 PM
might be ok under an exige hood maybe
#59 Exmantaa
Posted 05 March 2018 - 06:55 PM
Keeping the weight low and forward would be the aim in an Elise chassis.
And while talking aesthetics; that original Lotus Sport Exige does not look too shabby... :happy:
http://www.sandsmuse...sportexige.html
#60 mafumoto
mafumoto
  • 123 posts
Posted 05 March 2018 - 08:15 PM
I have a v6 c25xe sitting in the garage and always had this on my mind for a vx220 conversion but always had that nagging doubt of sticking a steel lump in the Ali tub So hence why now I've chosen the Audi v8 lump
