Loudi V8
149 replies to this topic
#61 mafumoto
mafumoto
  • 123 posts
Posted 05 March 2018 - 10:54 PM
some dimensions of project
https://farm5.static...281636169_b.jpg
https://farm5.static...39cfec33c_b.jpg
https://farm5.static...a956c96be_b.jpg
#62 mafumoto
mafumoto
  • 123 posts
Posted 06 March 2018 - 02:32 PM
[/url]">http://Posted Image
Edited by mafumoto, 06 March 2018 - 02:41 PM.
#63 mafumoto
mafumoto
  • 123 posts
Posted 06 March 2018 - 02:45 PM
#64 mafumoto
mafumoto
  • 123 posts
double post
Edited by mafumoto, 06 March 2018 - 02:48 PM.
#65 mafumoto
mafumoto
  • 123 posts
Posted 06 March 2018 - 02:47 PM
#66 mafumoto
mafumoto
  • 123 posts
Posted 11 March 2018 - 07:08 AM
Does anybody have the inner dimension of chassis where the subframe mounts plz
#67 mafumoto
mafumoto
  • 123 posts
Posted 12 March 2018 - 11:12 AM
 collected engine and got some quick dimensions
engine width inc thermostat housing at its widest point is roughly 840 mm
front to back inc thermostat housing and flywheel is roughly 500mm
engine is standing at 600mm at the mo but that doesnt inc the inlet manifold yet as unsure what style im going for
maybe an r8 or rs4/5
also the engine as is weighs in at 211kg
#68 Rosssco
Rosssco
  • 4,185 posts
Posted 12 March 2018 - 03:30 PM
Main issue is the front sump width vs. the lower wishbone mounts - not sure 840mm fits in between them.
Not sure what that all includes, but once you remove the DMF and all ancillaries like A/C and power steering, should loose some weight..
#69 mafumoto
mafumoto
  • 123 posts
Posted 12 March 2018 - 03:47 PM
yeah that is the concern at the moment the sump on this engine is very flat and shallow but very wide
i may look at the exige v6 suspension dimensions and work around them instead
#70 mafumoto
mafumoto
  • 123 posts
Posted 12 March 2018 - 03:49 PM
mind you with the fabricated subframe and engine width that could dictate the rear wheelbase.
#71 Rosssco
Rosssco
  • 4,185 posts
Posted 12 March 2018 - 03:51 PM
I guess you could potentially (given your fabrications skills) shorten the lower wishbone on the chassis side to allow the mounting brackets to move out wards slightly, and use a spherical bush in that particular wishbone point.
#72 mafumoto
mafumoto
  • 123 posts
Posted 12 March 2018 - 04:18 PM
yeah keep thinking that the lower arm seems very long and flimsey even tho i know it stands up to high power quite well
so yeah shorter but stiffer arm
#73 Rosssco
Rosssco
  • 4,185 posts
Posted 12 March 2018 - 04:52 PM
I wondered if it was feasible to cut out part the double sill section right at the front to provide another ~25mm clearance. I don't know if it provides any structural benefit to the tub, or is there simply to allow mounting points for engine torque and wishbone mounts..
#74 mafumoto
mafumoto
  • 123 posts
Posted 12 March 2018 - 05:01 PM
thinking of using them for part of the subframe mount
#75 Nev
Posted 13 March 2018 - 09:19 AM
Is it possible to cut the sump and re weld it to suit (assuming the crank/internals don't get in the way of doing this)?
If that's possible I would imagine it would be easier and less costly, and also you'd not have all the geometry issues to consider...
Also, if you made the sump say 2" deeper in the area near the pickup pipe (and extended that down by 2" too) then you'd eliminate any chances of oil starvation on hard cornering.
Edited by Nev, 13 March 2018 - 09:32 AM.
#76 mafumoto
mafumoto
  • 123 posts
Posted 13 March 2018 - 12:30 PM
Is it possible to cut the sump and re weld it to suit (assuming the crank/internals don't get in the way of doing this)?   If that's possible I would imagine it would be easier and less costly, and also you'd not have all the geometry issues to consider...   Also, if you made the sump say 2" deeper in the area near the pickup pipe (and extended that down by 2" too) then you'd eliminate any chances of oil starvation on hard cornering.
The sump on these engines are aluminium as part of the engine almost like a second crank brace with just a lid on the bottom I think the rs4 is deeper with a baffled pickup But it could be possible to put an extension on sump plate for the pickup
#77 VegyBS
VegyBS
  • 183 posts
Posted 21 March 2018 - 09:51 PM
This sounds mental, will be tracking. Also, hello from a fellow Barry boyo!
#78 mafumoto
mafumoto
  • 123 posts
Posted 22 March 2018 - 07:07 AM
Barry boys know how to modify😉
#79 slindborg
Posted 22 March 2018 - 02:58 PM
Very Pagani front end there
#80 mafumoto
mafumoto
  • 123 posts
Posted 22 March 2018 - 03:37 PM
