Loudi V8
149 replies to this topic
#81 mafumoto
mafumoto
  • 123 posts
Posted 07 April 2018 - 08:08 PM
cheers mark and joe the new kid is in awaitng the transformation
being guarded by the rotweiler
#82 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 07 April 2018 - 08:39 PM
So is this project starting now?
#83 mafumoto
mafumoto
  • 123 posts
Posted 07 April 2018 - 08:46 PM
it is
give it a week and ill start taking measurments and start designing the rear layout
#84 mafumoto
mafumoto
  • 123 posts
Posted 26 April 2018 - 10:57 PM
500mm from front edge of chassis to driveline
#85 mafumoto
mafumoto
  • 123 posts
Posted 26 April 2018 - 11:01 PM
front mounting dimensions
#86 mafumoto
mafumoto
  • 123 posts
Posted 26 April 2018 - 11:05 PM
the width of sump won't allow the engine to sit between the arm mounting points
#87 mafumoto
mafumoto
  • 123 posts
Posted 26 April 2018 - 11:08 PM
the left side of sump sits on top of the lower arm mount
#88 mafumoto
mafumoto
  • 123 posts
Posted 26 April 2018 - 11:10 PM
the right side of sump covers the arm mount
#89 mafumoto
mafumoto
  • 123 posts
Posted 26 April 2018 - 11:13 PM
plenty of space on left for engine and exhaust manifold
#90 mafumoto
mafumoto
  • 123 posts
Posted 26 April 2018 - 11:14 PM
same space on the right
#91 mafumoto
mafumoto
  • 123 posts
Posted 26 April 2018 - 11:22 PM
would need to either widen the mounts giving wider rear track but still keeping the same wheelbase if using the new style gearbox with front mounted diff
or extend the wheelbase further would need at least 220mm to get past the right side of the sump
#92 Rosssco
Rosssco
  • 4,185 posts
Posted 27 April 2018 - 08:08 AM
That's the money shot! It really quite a good fit, when you account for modifying the sump or suspension mounts, and the subframe..
#93 mafumoto
mafumoto
  • 123 posts
Posted 27 April 2018 - 09:18 AM
most definitely Rossco
I'm sure id even be able to keep the same wheelbase if I make a shorter lower arm  for those who would follow
would be nice to see an Exige v6 empty engine bay to see the comparison in arm mounts and the difference it would have around the sump
#94 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 27 April 2018 - 09:44 AM
most definitely Rossco  I'm sure id even be able to keep the same wheelbase if I make a shorter lower arm  for those who would follow   would be nice to see an Exige v6 empty engine bay to see the comparison in arm mounts and the difference it would have around the sump
If I get a chance I’ll pull the engine on mine and take some pics and measurements for you, if you want? I need to remake my engine mounts on the sides so will need to pull the engine anyway, as the mounts I’ve got in currently I don’t think are man enough.
#95 mafumoto
mafumoto
  • 123 posts
Posted 27 April 2018 - 09:46 AM
cheers mopey that would be great to see
did you make the mount points on the engine from solid or just made cups
#96 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 27 April 2018 - 09:50 AM
cheers mopey that would be great to see did you make the mount points on the engine from solid or just made cups
I’ll try and get in the garage today/ this weekend for you to pull the engine and get some measurements. What are you after? Same as you’ve taken above? From cups, it’s not the mounts that I made (copies of yours :P) that I’m worried about it’s the original VX and some crappy one I got off eBay that I don’t think will be man enough so I’m rethinking my design. I got some transit rear leaf spring bushes off eBay that are a decent girth that I think will be more suiting.
#97 mafumoto
mafumoto
  • 123 posts
Posted 27 April 2018 - 09:57 AM
lol
cheers mate I'm looking to see where the bottom arm points are in relation to the sump and also if there is a difference in the mounting points that I posted would be great to see a comparison
#98 mafumoto
mafumoto
  • 123 posts
Posted 27 April 2018 - 09:59 AM
if you need any help with your designs i can run them through an FEA test to see if they man up
#99 siztenboots
Posted 27 April 2018 - 10:11 AM
the position of the bottom wishbone pickup point does not matter as the gearbox will be so much further to the back , you will have to start again with everything.
#100 mafumoto
mafumoto
  • 123 posts
Posted 27 April 2018 - 10:13 AM
yes correct but it may be better to use the v6 arms with a new subframe
