2.4 Inlet Manifold
#41
Posted 27 July 2007 - 04:06 PM
#42
Posted 27 July 2007 - 04:23 PM
Vocky, would you be able to put a kit together with instructions that I could purchase from you? I would be happy for you to add a small percentage for doing the hard work
I would have the kit to bolt onto a standard engine... name your price! (Within reason
Am I right in thinking I would need the 2.4 inlet manifold, new gasket, egr valve blank plate, and also to modify the altenator slightly? Is it a relatively easy DIY job?
Otherwise I'd make a right pig's ear of it and my wife would be all like:![]()
Thanks!
I'm sure the 'tuning companies' will quickly catch on to this mod and sell a kit
usually some on ebaywhere sells a weld-in sport cat as in one of the z22se.org posts?
mine was a magnaflow and cost under £100
#43
Posted 27 July 2007 - 04:47 PM
it's too big for standard cams, only really needed with head work, cams, 4-1 exhaust etcWhat difference would the 2.4 TB make to a standard cam'd car?
#44
Posted 02 September 2007 - 03:00 PM
http://www.verboom.n...0824/index.html
Pretty happy with it
Mark
#45
Posted 02 September 2007 - 05:03 PM
#46
Posted 02 September 2007 - 05:24 PM
Iam I reading that right 37 hp from exhaust and inlet manifold?
#47
Posted 02 September 2007 - 05:47 PM
IIRC and that's without a remap I reckon it'll crack 160 at 6700rpm
#48
Posted 02 September 2007 - 06:17 PM
#49
Posted 02 September 2007 - 06:19 PM
Is that power at the wheels, or at the fly?
Wheel HP in 3rd gear.
#50
Posted 02 September 2007 - 06:21 PM
that's about 180-185 bhp at the flywheel
and a 58mm tb still
#51
Posted 02 September 2007 - 06:32 PM
#52
Posted 02 September 2007 - 06:35 PM
so you ditched the 68mm and still got good gains? would the 68mm be usable if it were remapped?
I think he needs some cams and headwork first, too much flow otherwise
#53
Posted 02 September 2007 - 06:39 PM
#54
Posted 02 September 2007 - 06:44 PM
#55
Posted 02 September 2007 - 07:23 PM
#56
Posted 02 September 2007 - 07:51 PM
#57
Posted 03 September 2007 - 05:25 AM
I wonder how much more a 4-2-1 or 4-1 exhaust manifold would give
Working on it
Mark
#58
Posted 03 September 2007 - 05:31 AM
#59
Posted 03 September 2007 - 07:23 AM
#60
Posted 03 September 2007 - 10:13 AM
Fitted mine last week, results are below:
Mark
(Im confused! Are you using the 68mm tb or the 58mm? What other performance mods do you have?( <- Ignore that! Ive read the guide through properly now!
Very impressed with the gains! Would it be easy for a mechanical novice to attempt?
Edited by andyroo, 03 September 2007 - 10:45 AM.
