marks RR needs a light recalibration but other than that It looks V nice
What makes you say that? From the callibration I've done, it was pretty accurate..
Im confused! Are you using the 68mm tb or the 58mm? What other performance mods do you have?
Very impressed with the gains! Would it be easy for a mechanical novice to attempt?
Hmm, I thought it was very clear on the page that I put up. I started out with the 68mm but it logged P1514, so I put the 58mm back on.
I would guess you should be able to determine for yourself if you want to try to fit it. There should be enough pictures and text up on my page so you can make a good guess..
Mark
