My Little Adventures...
534 replies to this topic
#281 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 27 August 2009 - 05:14 PM
no 5th october 2009!! for a few more ponies :rolleyes:
ponies/vodka lol
#282 The Batman
Posted 03 September 2009 - 06:34 PM
just picked up this sexy bad boy!
thanks again cliffie thumbsup
#283 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 03 September 2009 - 06:39 PM
That looks about 6X the size of the OEM one :o Are you keeping the OEM and using a swirl pot, or just taking a direct feed from the tank :blink:
#284 The Batman
Posted 03 September 2009 - 06:40 PM
not sure yet :lol: ideally i would love to swap the oem pump for this one but i dont have the time or the money really..... as you might aswell swap for the pro alloy long range fuel tank with built in swirl tank while you are there! maybe for christmas ;) so the plan was to use this as the feed from the swirl tank to the injectors :blink: its the bosch 044 pump :)
Edited by joe_589, 03 September 2009 - 06:41 PM.
#285 mandarinvx
mandarinvx
  • 12,621 posts
Posted 03 September 2009 - 06:43 PM
All you need to do is drill a hole and drop another pipe down there*
*Ok, so maybe not quite that simple :lol:
#286 The Batman
Posted 03 September 2009 - 06:44 PM
tell me more :)
#287 mandarinvx
mandarinvx
  • 12,621 posts
Posted 03 September 2009 - 06:58 PM
I may be completely wrong here, but I presume you want to use the new pump as the OEM one isn't man enough for the power level you want, so you plan to: OEM Fuel Pump > Fills Swirl Pot > Bosch Pump > Fuel Rail and/or Return to Tank But the limiting factor is the capacity of the swirl pot, which is essentially simply acting as a buffer tank Trouble is on long straights (esp the motorway) there's a good chance you'll empty the swirl pot if the OEM pump can't keep up (which you've already shown it can't) in which case the new pump may suffer together with your fueling I could however have this completely wrong, as the OEM pump will no longer be supplying a high pressure line (does it in stock form :blink:), instead it will be open end For the swirl pot I'd imagine you want a feed in from the OEM pump, a mid point take-off for return to tank and a bottom take off for the Bosch pump The best solution would be to simply put a line into the existing tank (keeping the OEM setup for level indication) and feeding that straight to the Bosch pump, then use the stock return to tank line But as I said, I could be completely wrong :lol:
#288 FrankenJim
FrankenJim
  • 653 posts
Posted 03 September 2009 - 08:40 PM
Hey joe, Hope your well. Where did you buy that header tank if i may ask? Are the plastic ones really crap at higher power? That beast is a aftermarket Fule pump right? Do you need a uprated fule pump on the higher bhp vx's ? On CS and TMS there power packs 4 dont seem to change that, Hence me asking you, or is there another reason? After the 5th , when i see you at a meet would love a pax ride if poss :-) Jim
#289 The Batman
Posted 12 September 2009 - 04:50 PM
progress so far with the swirl pot and pump
#290 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 12 September 2009 - 05:06 PM
nice braket lol
#291 The Batman
Posted 12 September 2009 - 05:07 PM
:lol: its work in progress! got to make a template before a nice shiny 1 can be made :)
#292 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 12 September 2009 - 05:10 PM
need new fixing ;) or advice :P for my clam when removed next month lol lol
#293 The Batman
Posted 12 September 2009 - 05:11 PM
lol what advice you want?
#294 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 12 September 2009 - 05:18 PM
Hi joe how much you pay for that nice big fuel pump? looks like it will do the job thumbsup
#295 The Batman
Posted 12 September 2009 - 05:20 PM
its an animal and it is very very sexy! :lol: bosch o44 pump thumbsup
#296 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 12 September 2009 - 05:24 PM
a new set of stainless still fittings lol or gold plated be ok
#297 vocky
Posted 12 September 2009 - 05:40 PM
looks good Joe thumbsup
#298 Winstar
Winstar
  • 4,264 posts
Posted 14 September 2009 - 04:22 PM
No it doesn't work like that. The operation of a pump follows a curve*, like a single speed line on a compressor map, that means that the less pressure head it has to provide the more flow it will give. Exactly how much will depend on the type of pump and specific design, also on top of this depending on how the motor to the pump is controlled as the load is reduced it could also spin faster so providing even more volume flow.
edit like thisclicky
Edited by Winstar, 14 September 2009 - 04:26 PM.
#299 slindborg
Posted 17 September 2009 - 10:04 PM
Also it will go tank pump -> swirl pot -> high pressure pump -> rail/reg -> return to swirl pot. the Swirl pot will take its highest outlet to the tank return. So the pot should have 4 connections to it. atleast one low one and then atleast 2 high ones and the other, well that isnt mega fussy where that is :lol:
#300 The Batman
Posted 18 September 2009 - 01:18 PM
Also it will go
this is the diagram i have been following:
and this is the swirl pot i have, it is a direct match to the diagram :)
