Its a VX turbo ...
Posted 03 July 2010 - 02:44 PM
Its a VX turbo ...
Posted 03 July 2010 - 03:48 PM
Its probably worth a call to Liam at MMG to discuss your budget vs best options to to you. He's a really decent guy and isn't going to rip you off by telling you need x, y & z.
Ok guys sorry to change the thread back to the original mmg stage 2 stuff...
I'm impressed with the power graph posted on the first page. Is the owner on this site & would be interested in the verdict on it?
Also not sure I can justify the stage 2 this soon after buying my vxt & have seen stuff on mmg stage 1 with great power gains but not as much torque. Does the car sound much different with the stage 1 precat removal & airbox mods? I must admit a bit sad at lack of exhaust note.
What I'm getting at (bear with me) is does the extra £1200 or so quid for the exhaust system which looks an impressive bit of kit really make a huge difference to final result & or sound of car compared to the stage 1.
I guess I'd really like stage 2 but would be grateful of your opinions as £'s not growing on my tree atm.
But the pre cat replacement, airbox mods and Milltek I have sound MUCH better than the standard set up
Posted 03 July 2010 - 04:23 PM
I've got exactly that- precat replacement, airbox trumpet removed (no holes drilled though) and MMG stage 1 remap (243bhp and 224lb-ft). In terms of performance I seem to easily out accelerate VXRs now and would imagine it is as good as most stage 2s, apart from there being less power low down. From 4.5k revs up I think they're pretty evenly matched.I'm still curious as to what soundtrack I'd get with the precat, airbox mods & remap alone without going for the exhaust system as you have?
Any ideas?
Posted 03 July 2010 - 04:31 PM
Trust you
Its a VX turbo ...
mine is a vx itb's
I was going to suggest that Spuk87 had the setup you were talking about and was going to suggest you PM him, but he's already beaten me to it
Any ideas?
The airbox mod makes induction and turbo noise much more noticeable, but don't remember it making much exhaust note difference.
The precat/remap makes the car sound much throatier at low revs but I don't think it affects high revs very much (IMO). I had it done 4 months ago though so can't remember what it was like before.
There is a good comparison video here.
HTH.
Posted 03 July 2010 - 05:31 PM
Posted 03 July 2010 - 06:02 PM
mmg stage 1 gives 243bhp & 224lb/ft
mmg stage 2 gives 258bhp & 291lb/ft
all of these could vary a little between vxt's though
Which (cogs whiring) makes a difference of 15bhp & 67lb/ft from stage 1 to stage 2.
The costs on mmg's site are stage 1 £475 & stage 2 £1775 which is £1300 difference.
Big torque improvement from stage 2 but big £'s diff so a tricky one.
Posted 03 July 2010 - 06:33 PM
Posted 04 July 2010 - 09:55 AM
Posted 04 July 2010 - 09:59 AM
As far as I know that graph is actually Turbobob's car.
Posted 04 July 2010 - 10:42 AM
Yep, though I wouldn't be surprised if a lot of people get those sort of gains. Sounds like Liam has done what he was considering and included the pre-cat in the stage 1- £475 is excellent value for money. Courtenay charge £500 excluding pre-cat if I recall.
The pre-cat is actually removed and replaced with a straight-through pipe which Liam gets fabricated for him- not sure who by. The pre-cat isn't legally required in this country and only works while the engine is cold anyway.
Posted 04 July 2010 - 10:44 AM
Posted 08 July 2010 - 04:35 PM
Posted 08 July 2010 - 07:06 PM
Posted 25 August 2010 - 06:56 PM
Edited by chrisgold, 25 August 2010 - 06:59 PM.
Posted 25 August 2010 - 07:01 PM
Posted 25 August 2010 - 09:58 PM
I think there was a bit of a typo on the web site before. Its always best to call Liam to get accurate pricing as I think the web site is still being developed.http://www.mmgperfor...php/38/stage-1-
EXCLUSIVE MMG SOFTWARE UPGRADE / DYNO READINGS BEFORE AND AFTER / INCREASES POWER 225 to 240 BHP
MMG stage 1+ remap
Pre cat removal pipe
A set cool running plugs
Air box modification
£575.00 (excl vat)
Cheap again!
Or just go all out first time stage 4....
Stage 4 nearly a grand cheaper than Courtenays as well (once you put the VAT on)...awfully tempting
Posted 26 August 2010 - 02:13 AM
Posted 26 August 2010 - 10:08 AM
Posted 26 August 2010 - 10:17 AM
Courtenay don't mention it either:Even at stage 2 , if you are running your standard clutch on a high torque map it is only a matter of time before you will get clutch slip. I am surprised that changing the transmission fluid is ignored.
CS 4**
Exclusive Courtenay Sport Software Upgrade, airbox modifications, Full stainless steel 3" 76mm exhaust system (including front pipe & 200cpi), Bespoke Charge Cooler System (see below for full details), Z20LEH (Astra VXR) Hybrid Turbo charger with stronger cast manifold, Uprated Actuator (not VXR actuator), Uprated Higher Flow Injectors, Rolling Road Tune
'Competition' Clutch Required if not already fitted.
Posted 26 August 2010 - 10:18 AM
