Brake Pads (Fast Road Use)
187 replies to this topic
#61 Hark
Hark
  • 3,443 posts
Posted 26 July 2012 - 08:36 AM
Just anyone run dot4 brake fluid instead of dot 5?? I changed to dot5 last October but needs changing every 12 months??? But I've only done about 1000miles.
#62 Bumblebee
Bumblebee
  • 7,592 posts
Posted 26 July 2012 - 08:38 AM
Yeah I guess it won't be that noticeable on speedline wheels think il just stick to the originals then :) I've got 5.1 fluid
#63 slindborg
Posted 26 July 2012 - 09:15 AM
use 5.1, far less maintenance involved. Although brake fluid should be done every 2 years worst case.
#64 Hark
Hark
  • 3,443 posts
Posted 26 July 2012 - 09:21 AM
I'm a rookie so why is 5.1 less maintenance?
#65 Bumblebee
Bumblebee
  • 7,592 posts
Posted 26 July 2012 - 09:40 AM
Think it has a Higher boiling point when I was on the 4 it went black really quick
#66 siztenboots
Posted 26 July 2012 - 09:47 AM
just use pagid dot4 , 0.5L should do you fine , I prefer the super low viscosity types but they are getting harder to find http://www.eurocarpa...70271&0&cc5_179
#67 TIP
TIP
  • 959 posts
  • Interests:cars. sci-fi, rum, bass, sheds, making stuff, fixing other stuff (mainly plastic vauxhalls) and other geeky bloke stuff
Posted 26 July 2012 - 10:02 AM
I was under the impression that Dot 5 was silcone based and should NOT be used in a system with dot 3/4/5.1 in because it would eat the seals?
whereas Dot 5.1 was gylcol based so compatible
Edited by TIP, 26 July 2012 - 10:02 AM.
#68 techieboy
Posted 26 July 2012 - 10:05 AM
Yep, DOT5 should never be used. DOT5.1 is fine though. Personally, I use RBF600 which is a DOT4 "racing" fluid which has much higher boiling points than 5.1. But I also change it two or three times a year as well, depending on how much of a beating it's taken on track.
#69 slindborg
Posted 26 July 2012 - 11:00 AM
so usually less than once a year because the car is in bits :P
#70 techieboy
Posted 26 July 2012 - 11:26 AM
No, it just means it goes about 300 miles between replacement. Wish the oil stayed that clean and fresh.
#71 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
  • Interests:Daft plastic cars
Posted 26 July 2012 - 02:01 PM
I'm ordering a set of 1155s tonight, as recommended by Donkey
#72 yaaan
yaaan
  • 956 posts
Posted 26 July 2012 - 02:53 PM
I replaced my 1144s with 1155s just before the National, took them on track after using the drive up to bed them in and they stopped my car whenever I needed it which is pretty much what's need of brakes. This may just have been because I was pottering around like Miss Daisy but certainly it was harder braking than I would expect to do on the road and had no problems. Having not used anything else I can't really comment on their suitability but it seems to me if you can get new pads and discs for £200 that will stop your car effectively, unless you're tracking lots, more expensive pads aren't going to offer any additional benefit. Each to their own of course :)
#73 Thealastair34
Thealastair34
  • 988 posts
Posted 26 July 2012 - 10:20 PM
i find my 1144 as a road car it stops better than any other car ive driven, im not sure what you do with your car but i would be asking do you really need a noisy track pad, or so you just want to buy them as everone else buys them?
#74 Boombang
Boombang
    Saxo boy
  • 3,022 posts
Posted 27 July 2012 - 06:43 AM
The 1155 works as well as 1144 from cold, when fitted with anti-rattle pads and buffers makes no more noise, copes better with high temps when tracked, lasts a great deal longer and also produces less dust. Only downside is technically should not be used on roads.
#75 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
Posted 27 July 2012 - 08:37 AM
I feel ripped off, all this talk of £200 for 1155s and disks from Camskill....including postage it comes to £201.94!! :P On the plus side, I got them ordered early yesterday, so should have them for fitting on Saturday....review to follow.
#76 slindborg
Posted 27 July 2012 - 09:17 AM
tbh they are cheaper now than when I got them, as it was £200 when I purchased cam skill discs and 1155's in 2009 :lol: so with inflation they are mucho cheap now.
#77 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 27 July 2012 - 09:25 AM
Why is that Alex? Are you referring to 1155 not technically to be used on roads?
FWIW I find the 1144s superb. No real dust deposits and great from cold. Bit squeaky until warm but who cares. I would also say that now having 250bhp ( I know, I know 249.8 :D) they cope very well.
#78 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 27 July 2012 - 09:37 AM
I found 1155s actually quite dangerous on the road, they need to be warm properly to work well. 2h's on the moterway off and up to round about, breaks! what breaks :lol:
#79 slindborg
Posted 27 July 2012 - 09:46 AM
Are you sure you had 55's and not 66/77's?
I never had an issue at all with 55's stopping power, even in sub zero temperatures first stop etc. Sure they were better when warm but NEVER dangerous.
#80 siztenboots
Posted 27 July 2012 - 09:59 AM
its a good habit to give the brake pedal an occasional go , 2 hours on a motorway you've got plenty of spare time to do it ready for an emergency stop.
