If they are valuing the salvage at £440 then you need at least £6k cash, ignore the stupid book price, hardly any vx220's sell at garages so the book price is just plan wrong
Just Crashed The Vx...
#141
Posted 22 September 2013 - 08:33 AM
#142
Posted 24 September 2013 - 01:30 PM
#143
Posted 24 September 2013 - 01:41 PM
doesnt the cost of the hire car also add towards the total cost of the claim , which would lower the total payout in the end ?
#144
Posted 24 September 2013 - 01:49 PM
#145
Posted 25 September 2013 - 11:52 AM
#146
Posted 25 September 2013 - 12:09 PM
#147
Posted 25 September 2013 - 12:13 PM
there will be a queue of VX round the corner at that price
#148
Posted 25 September 2013 - 12:14 PM
cost of paint would be couple hundred, that sounds abit off to me
#149
Posted 25 September 2013 - 12:19 PM
#150
Posted 25 September 2013 - 12:22 PM
He's using a 5 litre tin of Dulux and a 8" roller to apply it.
the 8" is a good choice
#151
Posted 25 September 2013 - 12:25 PM
I advise the use of a smaller brush for the tricky bits.the 8" is a good choiceHe's using a 5 litre tin of Dulux and a 8" roller to apply it.
#152
Posted 25 September 2013 - 12:27 PM
Whats the name of the company you will use to paint the car ?
#153
Posted 25 September 2013 - 12:41 PM
#154
its probably the same guys they used at the start of cannonball run 2
#155
Posted 25 September 2013 - 12:44 PM
#156
Posted 25 September 2013 - 12:46 PM
Told you.He estimates £55 for the paint.
#157
Posted 25 September 2013 - 12:50 PM
Just on this: 1. It's good practice to start any car with the clutch depressed 2. Most automatics require you to have foot on brake when starting Following those two principles should allows you to start 99% of cars (Unless you can't find the start button)Lost some man points and had to refer to the manual. 'Press the brake pedal and the clutch then press the Start Engine button'. What was wrong with turning an ignition key?
#158
Posted 25 September 2013 - 01:10 PM
Wow. Thanks. Re the repairs - one of the benefits of living in the north east rather than the south east perhaps. Anyway, crack on with the dulux jokes I'm just happy to be saving a sh*t load of cash.Just on this: 1. It's good practice to start any car with the clutch depressed 2. Most automatics require you to have foot on brake when starting Following those two principles should allows you to start 99% of cars (Unless you can't find the start button)Lost some man points and had to refer to the manual. 'Press the brake pedal and the clutch then press the Start Engine button'. What was wrong with turning an ignition key?
#159
Posted 25 September 2013 - 01:14 PM
Right up untill you have to get it painted again.Wow. Thanks. Re the repairs - one of the benefits of living in the north east rather than the south east perhaps. Anyway, crack on with the dulux jokes I'm just happy to be saving a sh*t load of cash.Just on this: 1. It's good practice to start any car with the clutch depressed 2. Most automatics require you to have foot on brake when starting Following those two principles should allows you to start 99% of cars (Unless you can't find the start button)Lost some man points and had to refer to the manual. 'Press the brake pedal and the clutch then press the Start Engine button'. What was wrong with turning an ignition key?
#160
Posted 25 September 2013 - 01:19 PM
Lol. Let's see the finished job. I am sure it will be fine.He's using a 5 litre tin of Dulux and a 8" roller to apply it.
