Original Engine Coming Out
what should i do with it?
140 replies to this topic
#61 fezzasus
Posted 22 June 2015 - 06:40 PM
Seriously is it a lump of iron like the turbos, or a light engine like the NA's. Have I just added weight to the car??
Martin S
It's aluminium.
But you may have added a bit of weight, maybe 10 kg - the sandcasted head will generally be denser, and the gen 3 block (correct me if i'm wrong, anyone) has been strengthened compared to the Z22SE block.
#62 Kieran McC
Kieran McC
  • 3,416 posts
Posted 22 June 2015 - 06:44 PM
Good time to go on a diet LOL
#63 CHILL Gone DUTCH
Posted 22 June 2015 - 06:58 PM
Seriously is it a lump of iron like the turbos, or a light engine like the NA's. Have I just added weight to the car??   Martin S
There is very little in it especially when you take into account the Saab oil cooler is lighter than the Z22se Your saving weight on the fly wheel and removing balancer shafts There loads of little things which saves you weight When moving my new engine around compared with old engine there were no noticeable difference Plus it was shiny
Edited by CHILL Gone DUTCH, 22 June 2015 - 06:59 PM.
#64 vocky
Posted 22 June 2015 - 07:16 PM
Does it weigh the same as the old one??
pretty much exactly the same weight, certainly no more than a couple of Kg
#65 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 22 June 2015 - 08:08 PM
I love how much you've researched and thought about this build Martin. :lol:
#66 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 24 June 2015 - 04:32 AM
Bought it on a wim as was given the impression it would just bolt in!
I'm not mechanical, I just like driving and because of that, I should be able to give a thorough and honest review of how this conversion actually works for real, on road and track as soon as I can (Spa is happening just a few weeks after it fires up), so should be interesting times ahead.
Martin S
Edited by MartinS, 24 June 2015 - 04:32 AM.
#67 siztenboots
Posted 24 June 2015 - 06:58 AM
get cracking then , the more time you can put to good now, will give you more to troubleshoot the usual stuff.
#68 vocky
Posted 24 June 2015 - 07:14 AM
they do bolt straight in, however converting them from turbo to NA or SC is not so simple  :mellow:
#69 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 24 June 2015 - 11:45 AM
Its looking like I will have just 10 days ish,  to run in and get to Spa as the car isn't ready yet and I have a holiday booked.
Martin S
#70 CHILL Gone DUTCH
Posted 24 June 2015 - 11:50 AM
Nothing like a last minute engine change 😬 I'm sure it will be fine Martin If you want to take a drive up north for the running in process I could help with the mapping
#71 techieboy
Posted 24 June 2015 - 11:55 AM
I'll pop over to Vocky's and run it in, whilst you're away, if you want? :D I ran my first uprated engine in on our first trip to the Le Mans double headers. Ran the second one in on journeys to and from three MSV trackdays in a 10 days. It's easy. :P
#72 siztenboots
Posted 24 June 2015 - 12:03 PM
sounds like when I had HGF two weeks before the big VX Le Mans eurotrip , ( http://www.vx220.org...-fed-pic-heavy/ )
somehow , we will get you there
where is the VX right now?
#73 siztenboots
Posted 24 June 2015 - 12:04 PM
see its an established tradition on here , break it just before the big summer event
#74 CHILL Gone DUTCH
This is starting to sound like a Disney film We will get you to the ball
#75 siztenboots
Posted 24 June 2015 - 12:07 PM
just reminded about sorting breakdown ins. for Spa and Frolic
#76 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 24 June 2015 - 06:18 PM
Have planned a night out in Bristol, that 350 miles for me, 140 back from Vockys (may make that into a 200), big thing will be understanding and using the software.
Sutol who only lives 25 miles from me will hopefully be my Yoda on that but appreciate the offer Chill.
Martin S
#77 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 24 June 2015 - 07:13 PM
Once it's mapped you can forget all about the software unless you tinker more with your set up. Get Peter to email you a map across based on your exact set up and it won't be far off.
#78 oakmere
oakmere
  • 2,143 posts
Posted 24 June 2015 - 07:18 PM
Mapping will be easy. Just leave the base map alone. Do a fuel learn approx 1 hour. Then a knock session 30 mins job done. Fine tune the map when you get back.
#79 oakmere
oakmere
  • 2,143 posts
Posted 24 June 2015 - 07:24 PM
As Acid says give Peter the full spec and you will be 95% there anyway.
#80 vocky
Posted 24 June 2015 - 08:17 PM
now I have seen a few z22se timing chains and some were quite terrible  :sleep:
But then there were these  :o
All from a certain engine which shall remain nameless  :ninja:
ps: it did have the 'death rattle' for one second on cold start up
Edited by vocky, 24 June 2015 - 08:18 PM.
