Original Engine Coming Out
what should i do with it?
140 replies to this topic
#81 Bargi
Bargi
  • 4,483 posts
Posted 24 June 2015 - 08:40 PM
Mr Vocky, please put up the pictures of the inside of Martin's engine, he said is was OK for you to show .org :D
#82 Rosssco
Rosssco
  • 4,185 posts
Posted 24 June 2015 - 09:00 PM
Seriously is it a lump of iron like the turbos, or a light engine like the NA's. Have I just added weight to the car??
Martin S
It's aluminium.
But you may have added a bit of weight, maybe 10 kg - the sandcasted head will generally be denser, and the gen 3 block (correct me if i'm wrong, anyone) has been strengthened compared to the Z22SE block.
This is the 'Gen 1' engine anyway, effectively albeit with forged rods and better pistons, meaning its much stronger internally. I think the 'Gen 3' variant was only ~1.5kg heaver due to block reinforcement anyway (to allow larger internal oil pathways, and better support for the piston liners - according to GM blurb)
In theory its slightly lighter, as the 2.0 crank is lighter being a 'square' engine, IIRC..
#83 fiveoclock
fiveoclock
  • 9,453 posts
Posted 24 June 2015 - 10:11 PM
Did you find the missing bit of piston anywhere??!!
#84 vocky
Posted 25 June 2015 - 06:12 AM
the only signs it was ever there were the missing chunk of ringland and the many dents in the piston crown before it escaped out the exhaust :mellow:
Weirdly the cylinder head survived with just a couple of tiny chips. The spark plug seems to have taken all the hits, so the head will live to fight another day :)
#85 CocoPops
CocoPops
  • 17,182 posts
Posted 25 June 2015 - 06:25 AM
How big was the piece of piston and presumably it's now wedged into the cat?
#86 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 25 June 2015 - 06:43 AM
Any damage too the bore?
New piston, rings and then It can be the spare engine for a while?
#87 fiveoclock
fiveoclock
  • 9,453 posts
Posted 25 June 2015 - 08:32 AM
Thats exactly how mine was, in fact my plug was worse than Martins but the head was hardly touched
#88 fiveoclock
fiveoclock
  • 9,453 posts
Posted 25 June 2015 - 08:34 AM
From looking at it with the scope it looked around 5mm to 10mm by about 3mm
#89 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 25 June 2015 - 08:38 AM
What causes this? Was martin's and 5'clocks the same cylinder?
#90 fiveoclock
fiveoclock
  • 9,453 posts
Posted 25 June 2015 - 08:47 AM
Yes and others and on Martins and mine the negative electrode had bent upwards and was touching the positive electrode
Edited by fiveoclock, 25 June 2015 - 08:50 AM.
#91 Bargi
Bargi
  • 4,483 posts
Posted 25 June 2015 - 09:31 AM
Have you got a photo of what the head looks like?
Interested to see if it was burning leaner from one end than the other.
#92 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 25 June 2015 - 04:58 PM
It ran great even with a chunk of piston missing and it and all looks fine to me!! You lot worry too much.
Martin S
#93 CHILL Gone DUTCH
Posted 25 June 2015 - 05:00 PM
Are you putting s wideband in Martin Since you will be pushing past 250hp it's recommended to use one for WOT mapping
#94 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 25 June 2015 - 07:31 PM
How do you put in a S Wideband (what is a S wideband?1!) what's WOT mapping , I seem to have entered a strange and mystical place where people talk in strange tongue?!
It was suggested doing the map learning then finishing with a rolling road that would check the upper and lower fuelling does that do the job?
Martin
#95 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 25 June 2015 - 07:38 PM
Fancy not knowing what a SwideBand is...its a bit like a gastric band !  :D
Edited by WrightStuff, 25 June 2015 - 07:43 PM.
#96 CHILL Gone DUTCH
Posted 25 June 2015 - 07:47 PM
It's just a wideband Martin ( sensor in exhaust ) Wot = wide open throttle
#97 vocky
Posted 25 June 2015 - 07:55 PM
Martin Saab's new engine looks much cleaner  :P
#98 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 25 June 2015 - 07:59 PM
Hmm if this were mine I'd be getting pretty excited.
#99 CHILL Gone DUTCH
Posted 25 June 2015 - 08:12 PM
Not using the brake vacuum pump Vocky It works very well
#100 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 25 June 2015 - 08:32 PM
With expensive trackways coming up I think he's more nervous (about the reliability) !
