Or you could buy the Mcguires headlight refurb pack, which includes detailed instructions, liquid, little graded numbered pads & small buffing wheel.
Already got that, use to use it on my MR2, is part of the plan to use it here also.
Posted 03 October 2015 - 06:03 PM
Posted 03 October 2015 - 06:04 PM
Or sell those and buy a set from fez when ya totally peed off with it
Definitely get some from fez if this doesn't work out. But I'm an optimist.
Posted 03 October 2015 - 06:06 PM
Halfords have a good selection and packs with a variety in. That's where I went after finding b&q etc didn't go fine enough.
While your out I would also buy some beers. Think you deserve them!
Yeah I know but Halfords are closed I have some wine in the Fridge, good idea!
Thank you B&Q:
2015-10-03_06-58-42 by Richard Fanders, on Flickr
Only problem is I have nothing in between 800 and 2500 until halfords opens tomorrow, so I'll try and get it to 800 tonight, I use all the grades in the pack I've just bought and go wet at 800.
Posted 03 October 2015 - 07:08 PM
180 grit, horizontal cross hatch by Richard Fanders, on Flickr
180 grit, horizontal cross hatch this time.
Posted 03 October 2015 - 07:54 PM
240 grit, vertical cross hatch by Richard Fanders, on Flickr
240 grit vertical, had to wet sand at 240 because the diall wet and dry sandpaper was not as good, kept getting clogged and causing deeper scratches. It gets easy the finer the sand paper is.
Posted 03 October 2015 - 08:12 PM
Looking good.
Just stop once those black numbers start start dissapearing.
Posted 03 October 2015 - 08:19 PM
320 grit, horizontal by Richard Fanders, on Flickr
320 grit horizontal. Horizontal is so much easier.
Posted 03 October 2015 - 08:40 PM
400 grit vertical by Richard Fanders, on Flickr
400 grit vertical, not seeing much difference now, maybe I should make bigger jumps between grades.
Posted 03 October 2015 - 09:02 PM
600 grit horizontal by Richard Fanders, on Flickr
600 grit, finally down to a sensible grade of wet and dry. Easier still
Posted 03 October 2015 - 09:40 PM
Posted 03 October 2015 - 09:50 PM
Been thinking about this as well, but I was thinking of starting with 1000 wet
Posted 03 October 2015 - 09:59 PM
Posted 03 October 2015 - 10:19 PM
2015-10-03_11-17-44 by Richard Fanders, on Flickr
2015-10-03_11-17-56 by Richard Fanders, on Flickr
Meguiars Headlight Restoration Kit
Posted 03 October 2015 - 10:21 PM
I will probably still try and spray lacquer on it for protection, although it's hard to get it smooth.
Bed time now.
Posted 03 October 2015 - 10:23 PM
I tried starting at 800 wet and dry but could not get the plastic protective coating off which was cracked. No matter what I did the cracking was still visible. So I wet kung fu sanding on it with 60. Now my hands and arms hurt.
Posted 03 October 2015 - 10:24 PM
I bought this as while back for a simlar project and it worked really well. http://pages.ebay.co...lobalID=EBAY-GB
12000 grit! Didn't know you could get that. May not even need to polish.
Posted 03 October 2015 - 10:37 PM
Posted 03 October 2015 - 10:51 PM
