Possible First Vx 2.4 Harrop 1900 Build
388 replies to this topic
#121 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 10 July 2016 - 07:35 PM
That's a good idea. I have my PCV catch tank in that area but could easily be relocated.
#122 1cobrav8
1cobrav8
    Joe is faster than me
  • 516 posts
Posted 10 July 2016 - 07:42 PM
When i get the custom tank designs through I'll post them on here. Anyone who wants a tank at the same time let me know. It will be baffled and hold about 8 litres. My idea is the then put a flush fit 1.75" filler with a 51mm neck on the body work to make it really easy to fill etc. Level will also be easily visible through the vent/ear.
#123 The Batman
Posted 10 July 2016 - 07:58 PM
that's exactly where I would mount the tank :)
#124 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 10 July 2016 - 08:02 PM
That was what I was thinking of with my tank, matching fuel filler on oposite side, tank other side of bulkhead though. Me being me I would want it to match though, dunno if I'm bothered enough to do bodywork too. Try a T off to the original map sensor hole on supercharger, injecting some there should effectively raise efficiency of the charger slightly, was not able to test properly myself, you having a RR should be able to see any diff, the 1/8npt adapter in the kit will just about screw in with some sikaflex alike as its not under pressure there. At least good enough for testing.
Edited by Crabash, 10 July 2016 - 08:07 PM.
#125 chris_uk
Posted 10 July 2016 - 08:44 PM
Don't think vxr injectors will cut the mustard on this one chris
i was just making comment about the rev limit in general ,, not specifically on this build.
Edited by chris_uk, 10 July 2016 - 08:47 PM.
#126 chris_uk
Posted 10 July 2016 - 08:47 PM
where are you going to mount the pump?
#127 CHILL Gone DUTCH
Posted 10 July 2016 - 08:48 PM
Good stuff chris But there is a lot more to it than that you could have two similar car and the duty cycle could be 10% difference quite easily
#128 chris_uk
Posted 10 July 2016 - 08:49 PM
which is why i said the limiting factor is the injectors...  :dry:
#129 CHILL Gone DUTCH
Think richard was talking about mounting the pump under the bracket/tank
#130 1cobrav8
1cobrav8
  • 516 posts
Posted 10 July 2016 - 08:57 PM
Yep as Chris said the pump mounts directly under the bracket
#131 chris_uk
Posted 10 July 2016 - 09:01 PM
ah right.
#132 Exmantaa
Posted 14 July 2016 - 09:57 AM
70mm pulley atm.....this may change. And Dutch Ecu, soon to be upgraded to the pro version
Was re-reading your specs, but on page 1 you mentioned an underdive ATI crank pulley on there?
If fitted that will affect the SC-rpm by some 12% for the Ecotec UD pulley according ZZP info. :rolleyes:
(makes your 70mm pulley act as a 78.4mm version...)
#133 vocky
Posted 15 July 2016 - 06:42 AM
It was not fitted due to the fact it needs to be pressed onto the crank, my concern was how it could be removed again :mellow:
To be honest I will never advise to fit one due to it being so tight into the oil pump gear. I measured the outside diameter and it was greater than a standard pulley - not ideal when the metal expands. After some serious track abuse (lots of heat) the oil pump gear might crack and thus kill the oil pressure. Be careful with them is my advice .....
Edit: it is running a 6 rib standard GM pulley
Edited by vocky, 15 July 2016 - 06:44 AM.
#134 1cobrav8
1cobrav8
  • 516 posts
Posted 31 July 2016 - 08:02 AM
With the new fuel pump and the inlet system fitted I put the car back on the Dyno yesterday to do some more base pulls without the MW50. Fuel pump has certainly done the job and we are now seeing 347ftlbs of tourque and 396bhp(6500rpm). When logging it is clear that the top end power is being killed dramatically by the fast rising inlet temps. We were reaching 80deg on these pulls. With the motor showing so much promise in these early stages I'm tempted to fit the larger pulley and try and remove some temps from the inlet. Before final mapping with the MW50 I think I'll try the larger pulley and see what characteristics it gives and decide from there. Custom MW50 tank is all designed and at the manufacturing stage now. Should have this early next week, it's got an inbuilt bracket to allow it to be mounted and sit in the right hand side pod with the pump bolted underneath. I will be able to offer these to anyone else who may want one but there not exactly cheap.....£150.
#135 techieboy
Posted 31 July 2016 - 09:36 AM
Will be interested to see the design of the tank. I need to fit one to the passenger side as i) my charge cooler pipework goes along the drivers sill and ii) with my lard arse in the drivers seat I need as much counterweight on the passenger side as possible :blush: and iii) a remote filler neck would be much easier to deal with on the passenger side away from spinning pulleys/belts. If they can do a mirror image of one, that would be perfect.
What capacity have you managed to make it?
#136 CHILL Gone DUTCH
Posted 31 July 2016 - 10:01 AM
Maybe ditching the meth also just run with H2O At least until we find some more detail about the Saab cracked block
#137 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 31 July 2016 - 10:08 AM
running Darton  liners
#138 Exmantaa
Posted 31 July 2016 - 10:35 AM
You've got a new dyno sheet of this pull? Interested to compare with the 1st and to see what rpm it drops the power..
#139 1cobrav8
1cobrav8
  • 516 posts
Posted 31 July 2016 - 06:22 PM
You've got a new dyno sheet of this pull? Interested to compare with the 1st and to see what rpm it drops the power..   I have yes, I'll try remember tomorrow to overlay them and add a photo up on here
#140 1cobrav8
1cobrav8
  • 516 posts
Posted 02 August 2016 - 12:42 PM
Below is the curve with the new fuel pump fitted and a little work done to the map over laid with the first initial pull.. IAT was rising massively during pulls which I believe is whats causing the big drop in power at the top end.
