Possible First Vx 2.4 Harrop 1900 Build
388 replies to this topic
#161 1cobrav8
1cobrav8
    Joe is faster than me
  • 516 posts
Posted 02 August 2016 - 07:04 PM
Has anyone else actually seen this dip on a Dyno rather than just the software?
#162 smiley
I think Lee is the only one who used an aftermarket ecu on his setup.
Is there a dyno run from that setup?
(to maybe rule out that we can put the limiter at 7800, but the ecu hidden logic may not agree with that choice)
Edited by smiley, 02 August 2016 - 07:06 PM.
#163 1cobrav8
1cobrav8
  • 516 posts
Posted 05 August 2016 - 07:09 PM
More progress today, to the point where the clam is going on tomorrow. Fed up of working and spending on it now. I want to be driving and mapping it on the road by sunday is the plan. A few pics of the completed install below...
Before everyone mentions it I know the filler pipe for the water tank is in a s**t location but i had to use whatever i had in the workshop today so that's what I came up with lol(still don't even know if the clam fits around it!) Hopefully the methanol has a higher enough flash point with it being 50% diluted with water  :huh:
Edited by 1cobrav8, 05 August 2016 - 07:13 PM.
#164 1cobrav8
1cobrav8
  • 516 posts
Posted 05 August 2016 - 07:14 PM
Broke an engine mount on the dyno, I did order and plan to fit a pair of vibratechnic mounts but there are on a week lead time fro everyhwhere so for now it has two new std mounts fitted and hopefully tomorrow if they turn up it will have polybush inserts in the front and rear mounts.
http://vid1157.photo...48855EC8DB2.mp4
Edited by 1cobrav8, 05 August 2016 - 07:16 PM.
#165 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 05 August 2016 - 08:32 PM
Good work mate looking good :-)
#166 chris_uk
Posted 05 August 2016 - 08:41 PM
i would look at moving them relays, they will be very close to the clam, that little nib actually pushes into the clam usually.
#167 1cobrav8
1cobrav8
  • 516 posts
Posted 05 August 2016 - 08:48 PM
Cheers Lee 👍🏼 I'll check th clearance tomorrow when trying the clam as I may need to move that filler pipe yet any way Chris, but thanks for the heads up
#168 fezzasus
Posted 05 August 2016 - 10:25 PM
Wouldn't have the relays exposed. The yellow and brown relays aren't waterproof and both of mine are dead as a result of water damage. Yellow one is in backorder from lotus without any delivery date
#169 1cobrav8
1cobrav8
  • 516 posts
Posted 06 August 2016 - 04:19 PM
So.... The clam is on and the car has been road tested with some base mapping and fuel learning. We completed a few power curves and i'm happy with the initial results. A lot still to be optimized, mw50 not working hard enough, fuel and ignition still not where i want it but overall its looking promising.....
#170 TFD
TFD
  • 607 posts
Posted 06 August 2016 - 04:37 PM
Thats a lot of power in a VX.... wow.. How come 1075kg? Two passengers I hope?
#171 1cobrav8
1cobrav8
  • 516 posts
Posted 06 August 2016 - 05:00 PM
My brother doing the laptop work 👍🏼
#172 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 06 August 2016 - 06:20 PM
Good to see you earlier mate Great results  epic power :-)
#173 chris_uk
Posted 06 August 2016 - 06:21 PM
Looks like you found same piece of road i did lol
#174 1cobrav8
1cobrav8
  • 516 posts
Posted 06 August 2016 - 06:48 PM
#175 CHILL Gone DUTCH
Posted 06 August 2016 - 06:50 PM
have you got any mapping done on yours yet lee
#176 1cobrav8
1cobrav8
  • 516 posts
And you mate. Couldn't have done it without yours and Neil's helps. Plus Chris(Chill) has been more than helpful with regards to the software! Mega chuffed 😁
#177 chris_uk
Posted 06 August 2016 - 07:04 PM
Joe made a joke about my power run which looked like yours,, he suggested i found a cobbled street lol.
#178 1cobrav8
1cobrav8
  • 516 posts
Posted 06 August 2016 - 07:11 PM
Always going to be a tricky one when doing power runs on the road especially with this power. You should have seen my attempt of a 2nd gear power run 😂😂😂. 1 wheel smoke screen #needadiff lol
#179 smiley
Posted 06 August 2016 - 07:12 PM
I was just about to say that when i noticed that graph :happy:
#180 1cobrav8
1cobrav8
  • 516 posts
Posted 06 August 2016 - 07:45 PM
You also need to bear in mind the ignition is still running pretty much base settings which when to regarded can cause these characteristics......smoother curve and more power is expected
