Sc Conversion Error Codes
163 replies to this topic
#81 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 27 August 2010 - 11:29 AM
Another one... did you at one moment turned the ignition key with the ECU not plugged on its connectors ?
What would that do?
It can block the immobilizer, I saw that a few months ago on a VXT
Only solution was going to a dealer...
What can a dealer do that an OBD and laptop cannot?
Edited by Cliffie, 27 August 2010 - 11:29 AM.
#82 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 27 August 2010 - 11:46 AM
Obd reads an ipm serial data loss and there was a dim error. Both of which, I though were codes that could be ignored? Based on reading about them and posts made on here and on z22se.co.uk? Plus I though even with the immobiliser on the car would still run for a few seconds?
#83 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 27 August 2010 - 12:02 PM
Nope. Immobiliser activated, no starty.
#84 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 27 August 2010 - 12:13 PM
May be the key to my last problem then :) Now.... Can this be cleared at home with an odb or do I have to tow to a dealer? It would be excellent to hear good news right now!
#85 alanoo
alanoo
  • 1,324 posts
Posted 27 August 2010 - 12:32 PM
No, it needs a Tech 2 dealer stuff apparently when I look at the archive of the french guy that had this specific issue
#86 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 27 August 2010 - 12:38 PM
If the immobiliser is activated, would it not inhibit the starter cranking over or just the spark?
#87 alanoo
alanoo
  • 1,324 posts
Posted 27 August 2010 - 12:40 PM
The starter is only activated via the dash "push to start" button and a relay ;)
#88 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 27 August 2010 - 01:04 PM
Would this bring up an eml light on the dash?
#89 Winstar
Winstar
  • 4,264 posts
Posted 27 August 2010 - 01:05 PM
You may be able to get to it with an OP-COM I managed to sort the alarm on my Astra, not sure if it'll talk the the Immobiliser though
#90 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 27 August 2010 - 02:49 PM
Is anyone around bury st edmunds Sunday evening or Monday? I have a slot at the local drive vaux, but I really don't trust them but feel I have no choice; how am I going to explain an sc conversion to them?!
#91 The Batman
Posted 27 August 2010 - 03:01 PM
so the only problem you are getting is its not putting fuel through the injectors right? so that leaves it to be either the fuel pump, fuel injectors, fuel rail, injector wiring check all these first, i hope you did one wire at a time and hope you havent mixed all the injector wires up!
#92 alanoo
alanoo
  • 1,324 posts
Posted 27 August 2010 - 03:55 PM
Truth is there's still no way to know if this is really the issue and the trip to the dealer may end with no solution :dry:
EDIT : I hate car electrics...
Edited by alanoo, 27 August 2010 - 03:56 PM.
#93 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 27 August 2010 - 04:06 PM
It's putting fuel through, it's just not getting a spark from the plugs :(
#94 The Batman
Posted 27 August 2010 - 04:10 PM
sorry im getting hugely confused with what you are saying. so fuel is no longer the problem, yet the problem is back to the spark.... so if there is no spark then it could be, battery, coil pack/amplifier, the little capacitor thingy connected to earth on the cam cover, possibly another earth problem somewhere else and finally the immobiliser...
#95 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 27 August 2010 - 04:45 PM
Sorry, i shall try to be more clear. It's putting fuel through, I was told it had spark originally but it currently does not. I have followed all off the earth cables off this system back to the various anchor points, swapped the little black box and back again, changed the coil pack to another and back again and ensured that all the points under the rubber bungs are in good condition for a contact. It has a new battery in it, new spark plugs from cms. Hope that helps :)
#96 The Batman
Posted 27 August 2010 - 04:47 PM
got to be something ecu/imobiliser related then surely.... :unsure:
#97 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 27 August 2010 - 07:11 PM
Hopefully an easy fix with the tech 2 then? What should I say when I take it down? Is there a specific diagnosis that I need to ask for?
#98 FLD
Posted 27 August 2010 - 07:21 PM
op-com will do immobiliser and alarm. Let me know if you need a loan. WRT the stealer: Just tell them your problem. Most are OK about SC conversions...or the guys in the garage are. The man in a suit at the desk is usually a knob.
Edited by FLD, 27 August 2010 - 07:22 PM.
#99 Karlosfandango
Karlosfandango
  • 437 posts
Posted 27 August 2010 - 09:01 PM
Sounds like you've been having some fun :tumble: I'd like to say I could help but I fear I'd be more use with a set of pom poms saying rah rah rah than wielding a multimeter. If you haven't set fire to it by the end of the week then I should be around should you need some random tools or things brought round thumbsup
#100 vocky
Posted 28 August 2010 - 11:30 AM
the injectors +12v supply comes from the relays in the boot, also the fuses in there should be checked too.
