Sc Conversion Error Codes
163 replies to this topic
#101 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 29 August 2010 - 12:15 AM
I checked the relays and even swapped in some from another car, as well as checked the fuses. Tomorrow I will check the coil amp is getting any power to it. I am going to take it to the dealers Monday, and if no luck there I will either just cry or just dump it at cms and see if they can play with it and get it working, thought it would be straight forward really, it's a shame I haven't had any fun out of the car before having to go back to work... Next weekend off will be mid October :(
#102 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 29 August 2010 - 09:39 AM
This is a major project Dave, stick with it and all will come good in the end and it will be well worth it.
#103 vocky
Posted 30 August 2010 - 04:45 PM
the ecu will prevent the engine from starting if there is a fault with the tb :closedeyes: I suspect that either the tb or the wiring is faulty (I know you have checked the wiring)
#104 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 31 August 2010 - 11:57 AM
After booking in at drive vaux in bury st Edmunds I was worried. I arrived and literally all the garage workers came out. Clawing over it in a mixture of admiration and sceptical fear. I got them to verify the millage by signing it off and after I explained jacking and how to open the various hatches. I really hope they don't mess it up. We tried two different 68mm throttle bodies, so I assume on that law of averages that it should be ok... Waiting on a call from the garage now.
Edited by davemate, 31 August 2010 - 12:18 PM.
#105 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 31 August 2010 - 12:17 PM
Just got a call from them. It's not running and they can't get it to start. So now I am stuck with a non working car. Any ideas where I can take it to? I have a trailer today but need to return it today.
#106 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 31 August 2010 - 12:49 PM
I would suggest Courtenays. You are welcome to drop it at mine but I doubt I can do anything you guys haven't tried. Vocky is really your man, if you can talk him into looking at it you may be on to a winner. He is not too far from me.
#107 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 31 August 2010 - 01:03 PM
Thanks man, text message sent. Anyone have vocky's number?
#108 Seb.F
Seb.F
    Under Your Bed
  • 6,045 posts
  • Interests:Tech head
Posted 31 August 2010 - 01:11 PM
Unfortunately I lost it :( there's plenty of us around this area that are more than willing to lend a hand.
#109 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 31 August 2010 - 02:08 PM
So get it to mine and all hands to the pump this weekend? That is a question, not yet an offer.
#110 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 31 August 2010 - 03:08 PM
Just got back fromthe useless vaux garage in town. Error p1612 error p1613 first one being immobiliser no or wrong signal. Vocky/anyone - can you work on this or should I justdump it at cms?!
Edited by davemate, 31 August 2010 - 03:12 PM.
#111 alanoo
alanoo
  • 1,324 posts
Posted 31 August 2010 - 03:12 PM
Have you tried with the second key ?
#112 Exmantaa
Posted 31 August 2010 - 03:45 PM
Posted Image Did they try a key re-learn procedure at the garage??
#113 vocky
Posted 31 August 2010 - 03:51 PM
the earliest I could look at it would be october :blink: you need to check the injector, crank sensor and map sensor wiring back to the ecu plug thumbsup otherwise it might be an idea to replace the complete wiring loom (like Lee had to do, he used my old z22se modified loom and it started ok), I do have one which I could convert, but I need to check with the looms owner how much they want for it :unsure:
#114 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 31 August 2010 - 04:12 PM
It took me half an hour to explain what the car was, and I tried to explain the immobiliser reset, but they said theycould not do this. I will charge up the battery(vaux drained it) and try the other key. Thanks vocky, will try thhose other checks next. Modified loom would be a good check.
#115 FLD
Posted 31 August 2010 - 06:09 PM
I have a spare loom you could try. It does have one issue that needs checking. Give me a tinkle if you need to try it. Op-com would do immobiliser coding. I'm pretty sure CMS would sort it pretty quick though. They are a good bunch.
#116 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 01 September 2010 - 10:13 AM
Cms have a 5 week waiting list and literally no room to even keep the car around and waiting :( Is anyone available to help? (Pm sent to FLD) -the car allows me to set and unset the immo, so this should imply that it is working? Lights blink several times fir on and once for off.
Edited by davemate, 01 September 2010 - 10:15 AM.
#117 slindborg
Posted 01 September 2010 - 10:19 AM
You on about setting the Alarm? (the immo and alarm are two completely seperate/different systems)
#118 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 01 September 2010 - 10:25 AM
(Pm sent to FLD)
Its the alarm that flashes the lights if you mean the indicators, iirc.
The immobiliser is the bit in the key/barrel and some code in the ECU that makes sure the 'key' is not just a screwdriver and the 'driver' is not a 14 year old pikey chav scum lowlife with 2 kids, 4 asbos and a council flat.
Hence the need to make sure the wires to the ECU need to be correct. It will control the ignition/fuelling/voodoo based on the pass or fail state of the immobiliser check, if my understanding of it all is correct :unsure:
The key will have a transponder chip in the case that is used to make sure the key matches the car. So trying the other key will help to rule out a problem with your main key.
#119 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 01 September 2010 - 10:28 AM
Ahhh, I will hunt the other key down- thanks. Thought the fob turned off the immo, thanks
#120 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 01 September 2010 - 10:39 AM
http://wiki.answers....r_work_in_a_car But, in all likelihood, all you will end up doing it ruling out a key transponder problem. The issue may still be in the wiring or the ECU has decided to forget your keys.
Edited by Ouchie, 01 September 2010 - 10:42 AM.
